FORUMS Photography Talk by Genre Transportation Talk
Thread started 09 Mar 2013 (Saturday) 11:49
How to take two exposures?
evan55
Joined Feb 2013
Mar 09, 2013 11:49 |  #1
I want to take a photo of my brothers car, and heard someone say to take two exposures, one for the sky and one for the car, then combine them.
I'm just wondering if that means putting the camera on spot metering and aim at the sky for one shot, and aim at the car for one shot? Or does this mean take one shot at -1 and +1 ev?
The camera will be on a tripod.
60D | Canon 50mm 1.8 | Tokina 11-16 | Sigma 18-200 | Canon 75-300 | RC-6 | YN-568ex | YN-622 | RØDE Videomic
3Rotor
Gallery: 52 photos
Mar 09, 2013 12:46 |  #2
It could be accomplished in many different combinations. You don't necessarily have to use only spot metering, you can meter for your desired effect in most modes. If you're metering for a dark car with a bright sky, you'll end up having car correctly exposed and a blown out sky. From the same position you could go down a stop or two depending on what you're looking for. Resulting in a correctly exposed sky and underexposed car. Finally, you'll create a composite in post. Three exposures is quite popular without having to do too much work; -1, 0, +1, -2, 0, +2, etc...
Instagram (external link)
www.jessemak.com (external link)
PhotosGuy
Joined Feb 2004
Mar 09, 2013 12:56 |  #3
Normally I'd move this to RAW, Post Processing and Printing, but since you asked about a car, I put it in T. Talk instead.
evan55 wrote in post #15695229 (external link)
Either would work, but I prefer to use this Need an exposure crutch? & bracket from -2X to + 2X, just to be sure that I have all the tones to work with.
What software will you be using for blending the exposures? Got Layer Masks? This is the overall best way that I've found for objects with hard edges like cars: Selecting areas in PS.
And don't forget that starting with the best light on the car will give you the best results. You have looked at the links in my Sig, right?
evan55
Joined Feb 2013
Mar 09, 2013 13:38 |  #4
PhotosGuy wrote in post #15695393 (external link)
Yep, I've looked at your posts. I plan on doing two exposures (sky and car) similar to this near the bottom of the page http://photocornucopia​.com/1035.html (external link) and using LR4 and CS5 to stack and blend the layers.
I'm also wondering if I have to move the camera do get the different exposures, wouldn't that kind of ruin the shot when I stack the layers? Or is there another way around this?
PhotosGuy
Joined Feb 2004
Mar 09, 2013 18:07 |  #5
evan55 wrote in post #15695478 (external link)
While you might move the camera to get the two exposures, you said "tripod" so we're assuming that you would not move the camera between the exposures? At least we wouldn't.
Joe ­ Ravenstein
Mar 09, 2013 22:59 |  #6
Bracketing will do the job you are wanting to accomplish. 3 shots minimum will do the job , one over one on the mark and one under exposed.
Canon 60D,18-55mm,55-250mm,50mm compact macro, AF ext tubes. Sigma 8-16mm uwa, 18-250mm, 85mm F1.4, 150-500mm
1,295 views & 0 likes for this thread
Latest registered member is markhilton
841 guests, 197 members online
