Thread started 10 Mar 2013 (Sunday) 10:56
Need Help, transferring external harddrives to stack.
Oz ­ Visuals
Mar 10, 2013 10:56 |  #1
Hey guys,
If I take my Western Digital My Books, break them open and take the internal drives (these are 6tb my books with (2) 3Tb drives internally) and throw them in a case that is connected to my system via an ESATA connector will Lightroom still be able to find my photos. I'm a little concerned because the WD MyBook shows up as 1 Drive but once I take them out and put them into the stack, it will I'm guessing show up as two drives.
Thanks for the help!
1D X (2), 1D Mark IV, 24L, 35L, 50L, 85L, 16-35L 24-70LII, 100mm 2.8L IS, 70-200 2.8L IS MARK II, 24mm TS-E 3.5L II, 600 EX RT (3)
Hasselblad 500C Zeiss 80mm Zeiss 150mm, Rolleiflex 3.5
Visit my website http://www.ozvisuals.c​om (external link)
or my blog http://www.ozvisuals.c​om/blog (external link)
mrfixitx
Gallery: 48 photos
Mar 10, 2013 11:00 |  #2
It depends on how you configure the case, is your WD Mybook USB 2 and you want to move to ESATA?
There are some ESATA cases out there where you can configure them to read multiple drives as a single disk.
Dodging and burning are steps to take care of mistakes God made in establishing tonal relationships! - Ansel Adams (external link)
http://www.brandons-photography.com/ (external link)
Oz ­ Visuals
Mar 10, 2013 11:44 |  #3
My current mybook is currently hooked up firewire 800. My Esata Case is just the nicest one I could get from Fry's but I didn't see any software or anything that came with it.
tonylong
...winded
Gallery: 60 photos
Mar 10, 2013 14:56 |  #4
Make sure everything is backed up! The other question will be if you have the two drives "RAIDED" together or just as two separate drives...? Two separate drives should be simple...
Then, when you hook up the ESATA stuff, see if it shows up as one drive or more than one.
However it shows up, you can start up your LR and in the catalog it should show the photos as "missing" if it can't automatically find them. If they are "missing" photos and folders should have a question mark icon and show the "missing" message.
From there, it's easy to get Lightroom to find them so that you can keep the metadata -- right-click on a "parent" folder and Browse to the related parent folder in your new drive system. Lightroom is "smart" about picking up the folders and images once you point it in the right direction. If your ESATA drives show up as more than one drive, you'd maybe be able to do this in just two operations, one for each drive.
Tony
Oz ­ Visuals
Mar 11, 2013 09:38 as a reply to  @ tonylong's post |  #5
Thank you so much guys!
778 views & 0 likes for this thread
Latest registered member is Dman780
1011 guests, 258 members online
