Thread started 10 Mar 2013 (Sunday) 11:51
self portrait. Request cc
medicdude
Mar 10, 2013 11:51 |  #1
hows this look to anyone with a calibrated monitor?
all critique appeciated
IMAGE: http://dustincurley.zenfolio.com/img/s8/v74/p1471069910-4.jpg
Dustin
R6II | Lenses
mrgooch
Gallery: 29 photos
Mar 10, 2013 13:12 |  #2
The colors look good to me . The lighting is a little contrasty.A relector on the left would have helped.
medicdude
Mar 10, 2013 13:54 |  #3
I had one on the left but I'm thinking it should've been closer, or positioned differently.
Dustin
R6II | Lenses
nes_matt
Mar 10, 2013 15:59 |  #4
I think you just need to bring the key around to the front a little.
Also, guys tend to do better with short lighting vs broad.
Canon 6D & Rebel T1i | Tokina 11-16 F2.8 | Sigma 18-50mm F2.8 EX DC Macro | Nifty-Fifty |85mm f1.8 | Canon 24-105 F4 | Sigma 70-200mm f/2.8 EX DG OS HSM
Flickr photo stream (external link)
Portfolio (external link)
Facebook Page (external link)
medicdude
Mar 10, 2013 16:04 |  #5
You're right, I do need to revisit that. Thanks!
Dustin
R6II | Lenses
PixelMagic
Mar 10, 2013 16:29 |  #6
Nice effort on the self portrait; they aren't as easy as you might think.
As already pointed out the key light was positioned incorrectly; ideally it should be at a 45 degree angle from the tip of your nose.
The lighting ratio is a bit contrasty but that can be solved with a bit of dodging and burning in Photoshop.
medicdude
Mar 10, 2013 17:34 |  #7
Pixel- thanks for that info. I was trying to keep the light off the backdrop, hence it's positioning. I will attempt another with it at 45 degrees. Maybe ill have to increase output of the backlight to keep it from being blown out by the key?
Dustin
R6II | Lenses
fashionrider
Joined Dec 2011
Mar 10, 2013 17:37 |  #8
medicdude wrote in post #15699475 (external link)
Are you using a black background with a blue gelled light? If possible, position yourself farther away from the background if you're worried about your key light spilling onto the bg.
Gear List (5D3, 70-200 f2.8L IS II, Sigma 85mm f1.4, Sigma 35mm f1.4, 50 f1.8, 24-105L, Alien Bee lights, etc etc)
medicdude
Mar 10, 2013 17:40 |  #9
Copy that. It's actually thunder gray seamless. This is all info i learned From the onelight dvd, just trying to remember it all! thanks. Can't wait to try again.
Dustin
R6II | Lenses
Condotierri
Joined Jan 2013
Mar 10, 2013 18:26 |  #10
If you're up for adding a third light source, I put a hairlight behind you.
The part where your bare skin transitions into the blue background has good separation. But the part where your hair transitions into the blue background could use a kick of light.
5D3, 60D || 8 primes, 9 zooms
1,057 views & 0 likes for this thread, 6 members have posted to it.
2188 guests, 130 members online
