I have 2 Manfrotto tripods with ball heads - one is lighter for travel, the other heavier duty. I find both to be a royal pain in the a$$ to get exactly where I want. No matter the lens I use, the camera creeps after locking it down. For example using my heavy duty set up and a 70-200 to shoot the moon, I frame the shot and tighten it down and when I let go, the moon is no longer center frame where I set it. Another example: I was adjusting my lenses last night using FoCal software. It requires you to set the center focus point on the center of a printed target. Even using a 50mm lens the ball head was horrible to position accurately. I had it as loose As I could get it and trying to make small adjustsments was problematic at best. The ball head wasn't smooth and easy to move unless wayyyyy loose and when I tried tried to tighten it a little to get some drag on it for small adjustments, it would stick and then jerk moving the target wayyyy out of frame. Frustrating. Yes. Very. Maybe I'm doing it wrong. I didn't think ball heads needed lubrication. I thought that once you tightened it what you framed was what you got. I frame it, lock it, let go and the camera drops enough to screw up my composition. It doesn't KEEP CREEPING- it's not broken that I can tell. It's just my hand holding the camera seems to be helping support the angle and when I let go it moves. It's is obviously much more pronounced at the telephoto end of the scale. Any tips?
Thanks in advance!
James
