FORUMS Photo Sharing & Visual Enjoyment Macro
Thread started 11 Mar 2013 (Monday) 18:53
First Stacking attempt
Pri
Joined Sep 2012
Mar 11, 2013 18:53 |  #1
This is my first stacking attempt ; The shots was taken with a reversed 50mm f1.8 on my 100mm macro lens and stacked using Combine ZM. 5 shots stacks for both pics! Would like to have you expert point of view about it ; C&C are most welcomed.
IMAGE: http://farm9.staticflickr.com/8525/8549362957_747b9155d2_c.jpg
IMAGE LINK: http://www.flickr.com …phy_mauritius/8​549362957/  (external link)
IMAGE: http://farm9.staticflickr.com/8376/8550461194_c44041d78e_c.jpg
IMAGE LINK: http://www.flickr.com …phy_mauritius/8​550461194/  (external link)
http://www.facebook.co​m …raphyMauritius?​ref=stream (external link)
Canon EOS 60D, Canon EFS 18-55mm, Canon EFS 55-250mm, Canon EF 100mm USM macro.
alquimista
Gallery: 91 photos
Mar 12, 2013 00:47 |  #2
Hi Pri, the stack quality is great; All you need to work out is your light angle and diffusion
la costura de Dios
http://www.flickr.com/​photos/andresmoline/ (external link)
LordV
Mar 12, 2013 01:49 |  #3
Came out well. Think I can see some haloing or duplication of hairs which needs a bit of editing.
Brian v.
Macro Hints and tips
Pri
Joined Sep 2012
Mar 12, 2013 04:37 |  #4
alquimista wrote in post #15705166 (external link)
Thanks Andres, i am using only one flash and I tried using a white cardboard reflector on the other side but did not get enough light on the bug. the other problen is the distance! What would you advise me to get a better result?
Pri
Joined Sep 2012
Mar 12, 2013 04:39 |  #5
LordV wrote in post #15705264 (external link)
Brian v.
Thanks Brian. Noticed that! mainly on the first one. What type of editing can get rid of that?
mandokid1
Gallery: 718 photos
Joined Nov 2010
Mar 12, 2013 09:41 |  #6
nice first attempt pri.
possibly 2 flashes if you have them,and you can clone the artifacts in PS
DENIS
Pri
Joined Sep 2012
Mar 12, 2013 14:35 |  #7
mandokid1 wrote in post #15706211 (external link)
Thanks Denis and thanks for the tips! I will receive a second flash soon :) So I will be try some more!
alquimista
Gallery: 91 photos
Mar 12, 2013 14:57 |  #8
Pri, you can try this set up,
IMAGE: http://farm9.staticflickr.com/8242/8551771037_37b003934d_c.jpg
IMAGE LINK: http://www.flickr.com …/andresmoline/8​551771037/  (external link)
set up (external link) by alquimista* (external link), on Flickr
I used this setup before,but with the MP-E, flash in manual mode 1/2 power, F11 but I should of done F9 4 shot stack
here is the result
IMAGE: http://farm9.staticflickr.com/8520/8551780085_e2d94312dd_c.jpg
IMAGE LINK: http://www.flickr.com …/andresmoline/8​551780085/  (external link)
sample (external link) by alquimista* (external link), on Flickr
hope it helps
la costura de Dios
alquimista
Gallery: 91 photos
Mar 12, 2013 14:58 |  #9
I know image is over sharpen lol it was when I was starting ;)
la costura de Dios
Pri
Joined Sep 2012
Mar 12, 2013 16:24 |  #10
Thanks for sharing the set up Andres! Very helpful. I must include the sheet of packing foam/velum paper over the lens to get more diffusion and also the white card below the subject to bounce light!
I will receive a Canon 270 exII flash soon (already ordered) along with Yongnuo YN-622C wireless trigger and I will try to use the Canon flash along with a Yongnuo YN468. Do you think it's a good idea? If yes how do I need to set up everything? Thanks
mandokid1
Gallery: 718 photos
Joined Nov 2010
Mar 12, 2013 17:33 |  #11
hi pri.here,s a set-up i,m working on for ish to use.just put it together a few days ago,and i,m using the 270 ex11 on it,and with the diffuser on the lens hood,so far the lighting is looking pretty good.
IMAGE: http://farm9.staticflickr.com/8101/8553290624_7ccf3eb9a3_b.jpg
DENIS
alquimista
Gallery: 91 photos
Mar 12, 2013 19:24 |  #12
great looking set up! cant wait to see results!
la costura de Dios
mandokid1
Gallery: 718 photos
Joined Nov 2010
Mar 12, 2013 20:44 |  #13
thanks andres.at least we put that ring lite away.LOL.now we just need spring to arrive.LOL
DENIS
Tiller
Joined Feb 2013
Mar 12, 2013 21:12 |  #14
Sorry to hijack the thread, but are you saying a speedlight is better than a ringlite?
Canon 60D|Tamron 90mm 52B|Canon 50 1.8|Canon 85 1.8|Yongnuo YN-568ex|Manfrotto 055XProb with 498RC2|Fuji AX Multi Program with 50 1.9 and 135 2.8|Mamiya 645 Pro with 85 2.5|
Website: http://tylersmcdonald.​com (external link)
mandokid1
Gallery: 718 photos
Joined Nov 2010
Mar 12, 2013 21:40 |  #15
Tiller wrote in post #15708784 (external link)
yes. in my opinion,and the opinion of many others,any speedlite properly diffused on a flash bracket to get it close to the end of the lens, will outperform a ringlite every time.
i gave up on mine trying to get nice diffused light out of it.
DENIS
1,996 views & 0 likes for this thread
Latest registered member is ShafferShots
1080 guests, 165 members online
