Thread started 11 Mar 2013 (Monday) 19:43
Photoshop edit
Rocky ­ Rhode
Joined Apr 2011
Mar 11, 2013 19:43 |  #1
Didnt like the tree branch sticking out of her leg: does the edit look ok?
ORIGINAL
With branch and shadows removed
IMAGE: http://i1103.photobucket.com/albums/g463/Roc34ky/AmericanRiver-2.jpg
GEAR LIST Flickr (external link)
Spike44
Mar 11, 2013 21:28 |  #2
Nicely done....I would rotate it to the right a bit to straighten, reduce saturation a bit and use a dodge tool to bring out her face a bit more.
abbypanda
Joined Nov 2011
Mar 11, 2013 21:37 |  #3
I think it's a good edit, the blues are overdone in my opinion
aboudd
Gallery: 13 photos
Joined Feb 2013
Mar 12, 2013 06:38 |  #4
The edit is a bit obvious. It is apparent that you cloned the same tree twice. When doing this it is better to pull the clone elements, assuming you can keep it looking natural, from more than one area. Also if you create a second layer, you can do the cloning there and then use the erase tool at varying percentages to make the retouching blend better.
Rocky ­ Rhode
Joined Apr 2011
Mar 12, 2013 12:02 |  #5
aboudd wrote in post #15705650 (external link)
Thank you; that is exactally the kind of feedback I was hoping for
Titus213
Mar 12, 2013 21:34 |  #6
I would also suggest opening up the shadows a bit after toning down the saturation, which looks quite heavy to me.
Dave
Perspiring photographer.
saea501
... spilled over a little on the panties
Gallery: 43 photos
Mar 13, 2013 07:30 as a reply to  @ Titus213's post |  #7
It does look a bit dark and saturated. I think the pose is a little awkward too.
Remember what the DorMouse said.....feed your head.
Bob
https://www.flickr.com​/photos/147975282@N06 (external link)
rivas8409
Joined Mar 2011
Mar 13, 2013 11:23 |  #8
It's a decent job of cloning. Someone other than those on this forum would probably not be able to see it. Compostion and exposure hosever are a different story. it took me a minute to realize that's she's more-than-likely a gymnist. As already stated her face is too dark and the perspective is off fo rme. I would have prefered the shot straight on...but it appears to be from a angle. Also, I think getting up higher would be benfeicial as well.
Body: Canon 5DmkII│Canon M50
Glass: Tamron 35mm f/1.4│Canon 85mm f/1.8│Canon 24-105mm f/4L│Canon 135mm f/2L│Canon EF-M 22mm f/2.0
Lights: Flashpoint XPLOR 400PRO│Flashpoint Streaklight 360│Flashpoint Zoom Li-on│AB800
Results: WEBSITE (external link)FACEBOOK (external link)
1,357 views & 0 likes for this thread, 7 members have posted to it.
Photoshop edit
645 guests, 120 members online
