Thread started 13 Jan 2006 (Friday) 00:11
Please help me fix this pic.
shakin360
Jan 13, 2006 00:11 |  #1
A bunch of my shots from this accident turned out like this. I assume because I was shooting into the sun. I tried messing with it but couldn't get rid of the hazy flare or whatever towards the top. HELP!
Here is an untouched copy. It is shot with Fine JPG.
www.myspace.com/aophot​ography (external link)
http://www.modelmayhem​.com/member.php?id=121​511 (external link)http://www.modelmayhem​.com/aophoto (external link)
www.photokenosha.com (external link)
Kristy
Gallery: 31 photos
Location: A dream world where nothing is what it seems.
Jan 13, 2006 00:15 |  #2
Start shooting in raw..... It's difficult to fix exposure problems without a raw file. With raw, you can do miracles.
Oh, and you could mess with the levels/curves adjustment for this jpeg.. might help, but you may not recover all. I've made
my share of exposure mistakes... frustrating, huh?
Life is not measured by the number of breaths we take,but by the moments that take our breath away.
~George Carlin
Kristy :D 5D MkIII, 24-70 / f2.8 L, 2 AB800's, and some modifiers.
My Website Page (external link)
Kristy
Gallery: 31 photos
Jan 13, 2006 00:17 |  #3
By the way.. cool shot!
~George Carlin
shakin360
Jan 13, 2006 00:24 |  #4
yeah, some from this shoot turned out but all from this angle had this problem. I keep putting off shooting RAW, i don't know why. Actually as I'm typing this I'm downloading the RAW plug-in for CS. I tried levels and few other things (can't figure curves out yet) and the lower half doesn't look too bad, just the top is all jacked up.
Thanks, i posted some of the better ones in the Urban board.
dwterry
Jan 13, 2006 00:27 |  #5
Steps taken:
1) First I just brought up levels and hit Auto. That did 95% of the work right there.
2) Then I added a small curves adjustment because I felt that levels left the image too dark, so I brighted it just a bit.
3) Then I bumped up saturation of yellow by +15 and red by +10.
4) Then I applied a little USM for "Local Contrast". I did that by applying USM at 15% with a 60 pixel radius.
5) Finally sharpened and saved.
Weddings, Portraits, Seniors, Models
http://www.dterryphoto​graphy.com (external link)
http://blog.dterryphot​ography.com (external link)
Kristy
Gallery: 31 photos
Jan 13, 2006 00:31 |  #6
You know, I put off shooting Raw for a LONG time. I finally tried my first raw shots in October ... DUH... was all I could think. Everything looks better in raw... skin tones more natural, it's weird.... much better quality. I've been using Raw Shooters Essentials. Lots of info about it here on the forums. works great and very easy to use... I don't think I will ever go back to jpeg. I usually shoot Raw and low level jpeg.. I'm not sure why I think i need the jpeg to be there, but it feels like a safety net of some kind. Anyway,,,, give it a try, you'll wonder what you were waiting for.
~George Carlin
Kristy
Gallery: 31 photos
Jan 13, 2006 00:33 |  #7
Nice Edit dterry.., :)
~George Carlin
dwterry
Jan 13, 2006 00:35 |  #8
I agree. At least RawShooter Essentials. It's free. If you happen to like it - you'll find that you'll really love RawShooter Premium. It costs a little (but to me it's very reasonable). I shoot just about everything in raw except for fast action sports.
tombryan
Jan 13, 2006 00:36 |  #9
Ok, I downloaded your pictures and it's a couple of megs. I can't reupload it because it says it's too big. How did you manage to upload such a big file ??
Ok, I just uploaded it as big as it would let me. Not big enough for you to save, but big enough for you to see hopefully. Check your PM. You can email me and I'll email the full size file.
Tom Bryan
Bryan Photography
http://www.bryanphoto.​com (external link)
2 Canon 20D w/ battery grips
Tamron Sp 17-50mm f/2.8 XR Di-II LD (IF)
Canon 24-70 L 2.8 USM
Canon 70-200mm 2.8 L IS
2-Canon 580 EX Speedlites
Omni Bounces and Fong's Org. Lightsphere
shakin360
Jan 13, 2006 00:45 |  #10
I dunno, all I know is that I just have it hosted on photobucket.
tim
Light Bringer
Jan 13, 2006 01:02 |  #11
I had a play too, auto levels, add contrast, and perhaps play with the color ballance, like Terry did. It gets a lot better, but it'll never be perfect image quality. One idea to prevent this in future is using your hand to shade the lens, or moving to put the sun more to the side.
shakin360
Jan 13, 2006 01:23 as a reply to  @ dwterry's post |  #12
dwterry wrote:
Steps taken:
The ones I tried ened up like this. Which is much better, but is there a good way of getting rid of the haze at the top.
Thanks for all the help so far.
Palladium
Jan 13, 2006 08:41 as a reply to  @ shakin360's post |  #13
duped original and changed the view mode from normal to multiply
duped the new layer from above and added a mask and used the gradient to only show the top third (hazy stuff) - duped this layer and again set it to multiply and reduced the opacity
saved - a couple of clicks and a couple of seconds
tombryan
Jan 13, 2006 08:53 as a reply to  @ Palladium's post |  #14
Shooting RAW helps with exposure problems in tricky outdoor lighting situations when you don't really have time to dial in your exposure after metering and setting everything manually. But it's not going to get rid of the haze when you are shooting into the sun like was done here.
You can however do a good job of getting rid of the haze in Photoshop if you know what you are doing.
Tom Bryan
Bryan Photography
Robert_Lay
Jan 13, 2006 09:30 |  #15
I notice that your equipment list indicates hoods with the lenses. I'm not familiar with those lenses or whatever hood comes with - however, for future reference, when shooting into the sun, it helps to hold one hand out in front and above the lens and adjust its position until you see the playback of the image on the screen regain its contrast. Usually, with a little care this can be done without having your hand in the image. A little precaution like that can avoid hours in post processing.
The problem arises from the fact that the front element of the lens was in the direct view of the sun. The forward scatter of the sun's rays appears in all parts of the image and weakens or washes out the shadow areas to the point where there is no contrast left. Easy to avoid if you take the trouble to notice the effect.
Bob
Quality of Light (external link), Photo Tool ver 2.0 (external link)
Canon Rebel XTi; EF-S 10-22mm f/3.5-f/5.6 USM; EF-S 18-55 mm f/3.5-f/5.6; EF 28-135mm f/3.5-5.6 IS USM; EF 50mm f/1.4 USM; Canon Powershot G5; Canon AE1(2); Leica R4s; Battery Grip BG-E3; Pentax Digital Spotmeter with Zone VI Mod & Calibration.
3,015 views & 0 likes for this thread, 13 members have posted to it.
1669 guests, 135 members online
