Thread started 13 Mar 2013 (Wednesday) 08:52
Flash Remote Trigger.
SpartanWarrior
Mar 13, 2013 08:52 |  #1
I am in between these 2 Cactus V5 or the Phottix Atlas II, which one should I go for? thanks;)
Canon 5D III, EF 24-105 f4, EF 16-35 2.8 L II, EF 70-200 2.8 IS L II, EF 100 2.8 IS L, EF 2x III, EF 1.4x III, 500D 77mm close up filter, Kenko extension tubes set, SpeedLight 600 EX RT, Metz 58 AF-2, Pixel Kings, Benro C3780T Tripod, Benro G3 Ball Head.
www.chrisksphotography​.com (external link)
elv
Mar 13, 2013 09:13 |  #2
That's a hard question to answer without a lot more detail about what you hope to achieve or what gear you are using etc. I have a guide to the common manual triggers up here that may be of some help though -
http://flashhavoc.com/​flash-trigger-guide-manual/ (external link)
The Atlas II are in a different price range, but very good value for the price.
FLASHHAVOC.COM (external link)
SpartanWarrior
Mar 13, 2013 10:27 |  #3
elv wrote in post #15710245 (external link)
Thanks, I have the metz 58 AF-2 and 600 EX RT and just wanted a good full manual only triggers, So stuck between those 2, thanks for the link.
elv
Mar 13, 2013 19:52 as a reply to  @ SpartanWarrior's post |  #4
Ok, well the Atlas II are really in a different class, the V5 are designed to be a budget option.
Provided you don't mind the high profile of the Atlas Tx on the camera, or need the V5's manual pass through hotshoe for anything, the Atlas II are more refined with twice the range and higher quality. If moneys not the issue that's a fairly easy choice :-)
SpartanWarrior
Mar 14, 2013 02:52 |  #5
elv wrote in post #15712371 (external link)
Ok thanks, it's the Atlas II then;)
910 views & 0 likes for this thread, 2 members have posted to it.
615 guests, 124 members online
