Hello all,
I am heavily invested in the Lowepro S&F system (and am NOT looking to sell it all off to switch systems), but I need a holster. I want something that will comfortably hold an ungripped 7D with a 70-200/2.8 or 100-400 with hood reversed. I will be using this for hiking (need for all-weather covers) and event work. Bulk and weight are things that I would want to avoid as much as possible. As I've been researching, the options that come up are:
1) Lowepro Toploader Pro 75 AW
Pros: designed for S&F system, better padding, consistency (all of the rain covers behave the same, etc.)
Cons: bulkier, will ungripped camera bounce around inside?, will camera with shorter lens bounce around inside?
2) Think Tank Holster 30 V2.0
Pros: designed for ungripped camera, less bulky, pop-down feature is really nice
Cons: Can the plastic tongue in the Think Tank system work (or be modified to work with the S&F system)?
3) Think Tank Holster 20 V2.0
Pros: designed for ungripped camera, less bulky, would pop-down feature allow me to carry the 100-400 (hood reversed) in the pop-down configuration while fitting a shorter lens better in the pop-up configuration?
***So, my main questions are:***
A) Can the Think Tank holsters be used or reasonably modified to work on a Lowepro Deluxe Tactical Belt in a way where they would not flop around more than a comparable Toploader model?
B) If the answer to (A) is yes, then can the Think Tank Digital Holster 20 v2.0 reasonably hold a 7D with 100-400 lens (hood reversed) in the pop-down configuration (or would I need to get the 30)?
Thanks for the feedback on some fairly specific questions!
