Thread started 13 Mar 2013 (Wednesday) 11:18
Zeiss C/Y lenses with 5dm3 help
dkizzle
Joined Mar 2012
Mar 13, 2013 11:18 |  #1
I am looking to add another Zeiss lens to my collection and started doing research on C/Y zoom lenses. My research indicates that Zeiss 35-70mm and 28-70mm do not cause any issues with hitting the mirror on 5dm3 (when used with a good adapter).
Can anyone provide real life experiences with using C/Y lenses on 5dm3?
I want to guest blog on your Landscape / Travel photography blog, PM for details
TSchrief
Joined Aug 2012
Mar 13, 2013 14:28 |  #2
I have used C/Y lenses on my T1i and 60D with no problems. I read of others using them on the original 5D with no problems. I have no first hand information about C/Y on FF digital bodies.
Most of my comments are about lenses. I had two really exceptional C/Y lenses. The first was marketed by Vivitar - the 28-105mm zoom. I think it was actually made by Tokina and was f/3.5-4.5. I donated that one to a local high-school with a bunch of other C/Y bodies and glass. The other really good C/Y lens, which I still have, is the Vivitar 70-210 f/3.5. I got this lens for $99 on e-bay. The serial number starts with 37, so I know it is a Tokina product. This really is a top-flight lens in every respect. IQ and build are superb. It is smaller, but heavier, than the EF-s 18-135 and f/3.5 at 210mm is pretty darn fast!
One other lens that is worth buying is the Yashica 135mm f/2.8 MLc. All around winner, in my book.
Yashica marketed a lot of mediocre lenses. Most of them were designated DSB or YUS, in the model name. The good stuff was designated ML (multi-layer), MC (multi-coat) or MLc. The 'c' is for compact. These are completely different lenses, with different coatings, than the DSB/YUS stuff. There is a lot of DSB/YUS stuff out there, and it is appropriately inexpensive.
The good stuff is harder to find and more expensive. I find that most people selling this stuff on e-bay don't even know what they have. It was handed down from grandpa, or found in aunt Mable's place after she left this world. Some really good bargains are out there, if you keep your eyes open.
Canon ­ Bob
Mar 13, 2013 16:42 as a reply to  @ TSchrief's post |  #3
I've got a Zeiss 28mm in CY mount that works fine on my 1Dx and I doubt that the 5D3 mirror swing arc is any different.
Bob
1Dx2 (2), 5DSR, 1Ds3, 1D4, 5D2(590nm), 5D2(720nm) EF600 EF400 EF300-II EF300 EF200 EF200-II EF180L EF135L EF100 EF85-II EF50L TS-E17/4 TS-E24L-II TS-E45 TS-E90 MP-E65 EF70-200-II EF24-70/2.8-II EF16-35/4 EF8-15/4 EF11-24/4 Zeiss 15/2.8 21/2.8 25/2 28/2 35/1.4 35/2 50/2 85/1.4 100/2 135/2 T/C's L-SC & a WIFE!
dkizzle
Joined Mar 2012
Mar 13, 2013 20:27 |  #4
Thank you both for comments. I have been looking around on Fleabay and keeping my eyes for the lens I originally mentioned. I will take a look into Vivitar 70-210, if I can get it for that cheap I will definitely pick up a copy.
I dont have any C/Y lenses at all but I did manage to pick up a minty CZ 35mm Flektogon last year in M42 mount which works fine on my 5dm3.
TSchrief
Joined Aug 2012
Mar 13, 2013 21:57 |  #5
Good luck with your search. Here is a link to an article describing some of the Vivitar Series 1 70-210 zooms.
http://www.robertstech​.com/vivitar.htm (external link)
There is a lot of good information in there. I have version 2, as described in this article. The simplest way to distinguish them is by the look of the focal length scale. Filter size is also helpful. I can post/e-mail some photos of my lens if you want them. The focal length scales make them pretty easy to tell apart.
I wish you could handle this lens. The focus and zoom are as smooth as silk. One thing is a tad annoying. Keep this in mind: you have to turn the aperture ring; it is manual selection only. There are nice positive click-stops every one-half stop between f/5.6 and f/22. That is nice. There are no click-stops between f/3.5 and f/5.6. If you are counting, you will get confused the first few times you use this lens.
I have seen people complain that C/Y glass will not give a confirmation beep (requires proper adapter) when stopped down to f/8 or narrower. They are not using their equipment properly. That has nothing to do with the lens. It is their camera. Not many Canon cameras can focus at f/8. Duh!
Proper sequence of events for shooting C/Y glass on an EOS body is:
Start with ISO and shutter speed in the right ballpark.
1.) Set wide-open aperture.
2.) Focus. Always focus wide open to give your camera the most light to work with. EF lenses do this automatically.
3.) Frame your shot.
4.) Adjust aperture to desired exposure.
5.) Release shutter.
Focus wide-open, just like you EF/EF-s lens do. Stop down just before releasing the shutter, just like EF/EF-s lenses do. You'll be fine. Happy manual shooting.
TSchrief
Joined Aug 2012
Mar 13, 2013 22:07 |  #6
I couldn't resist.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/03/2/LQ_640768.jpg
Image hosted by forum (640768) © TSchrief [SHARE LINK]
dkizzle
Joined Mar 2012
Mar 14, 2013 04:27 |  #7
Looks like someone has some reading and fleabaying to do when he gets to work.
titi_67207
Mar 14, 2013 04:47 |  #8
Hi, I'm using a Zeiss C/Y 85mm f/1.4 on my 5D and that's a pleasure to use it. The all metal construction is a joy to use.
For the lenses suggerated, I would take the 35-70 which had and still has a great reputation. And it's a light lens + has macro/proxy abilities.
Titi
Canon 5D MkII + Sony A7 + 24x36 & 6x6 B&W film cameras .
CV 15 4.5 III | TS-E 24L II | FE 28 2 | (50+85) 1.4 | 135 2 | 70-200 4.0L | a collection of old Zuikos + FD + Adaptall + AI-s + M42
dkizzle
Joined Mar 2012
Mar 14, 2013 09:32 |  #9
Thanks, it seems French sure love Zeiss lenses.
I want to get a Zeiss zoom as I am not too happy with the results of 24-105mm 4L. Most of the stuff I should is using a tripod so MF should not be a problem.
electronpusher
Gallery: 39 photos
Joined Mar 2012
Mar 14, 2013 13:41 |  #10
Not sure if the 5DII and 5DIII have the same clearance, but my 5DII will work with all the Zeiss C/Y lenses in my sig, except the 18, which hits the mirror. All are solidly built and have velvety focusing.
Canon 5D mkIV | Canon 1D mkIII | 24-70mm f/2.8 II L | 70-200mm f/2.8 II L | 70-300mm f/4.5-5.6 L | 17-40mm f/4 L |100mm f/2.8 L Macro | 50mm f/1.8 II | Kenko 1.4x Teleplus Pro 300 DGX | 600EX-RT
Contax RTS
| Zeiss T* 18mm f/4 | T* 35mm f/2.8 | T* 50mm f/1.4 | T* 85mm f/1.4 | T* 135mm f/2.8 | T* 200mm f/3.5 | Fotodiox chipped adapters, Contax/Canon
dkizzle
Joined Mar 2012
Mar 14, 2013 15:16 |  #11
electronpusher wrote in post #15714960 (external link)
Thanks for the report.
johnf3f
Mar 14, 2013 19:29 |  #12
I am using the Contax-Zeiss 25mm F2.8 (supposed to be one of their poorer lenses) on a 1D4 abd 5D and love it!
This site may be helpful regarding compatibility: http://www.pebbleplace​.com/Personal/Contax_d​b.html (external link)
Life is for living, cameras are to capture it (one day I will learn how!).
dkizzle
Joined Mar 2012
Mar 15, 2013 07:00 |  #13
johnf3f wrote in post #15716118 (external link)
Thanks, I found this website during my searches. I also know that he sometimes sells lenses on Fleabay. Unfortunately his website only talks about primes, not zooms.
Canon ­ Bob
Mar 15, 2013 07:41 |  #14
dkizzle wrote in post #15717399 (external link)
At the bottom of the chart are tabs for pages 2 and 3....the zooms are on page 3.
Bob
dkizzle
Joined Mar 2012
Mar 15, 2013 17:43 |  #15
Thanks, I didnt see that it had multiple pages.
*add* I originally found this page - http://www.pebbleplace​.com …x_db_Specific_L​enses.html (external link) not page that you gave me, thanks again.
4,134 views & 0 likes for this thread, 6 members have posted to it.
Latest registered member is finnianmarlowe
1341 guests, 176 members online
