Thread started 14 Mar 2013 (Thursday) 16:28
Canon 430 EXII tutorial?
waylandcool
Gallery: 6 photos
Mar 14, 2013 16:28 |  #1
I have a 430EX II that I use with my Rebel and I know that I am not getting the most out of it. Right now when I use it, I switch the manual and go with the settings that will give me the best shot. I'm pretty sure that there are better ways to do it. Are there any tutorials or online references that can point me in the right direction?
apersson850
Obviously it's a good thing
Gallery: 35 photos
Mar 15, 2013 02:22 |  #2
Usually, it's more important to have knowledge about flash photography in general than a specific flash model. Once you know what can be done, and what you can do, then how to do it with your particular flash is either obvious or just a quick look in the user's guide away.
Try the IMPORTANT LINKS at the beginning of this forum first.
Anders
Tiberius
Mar 15, 2013 03:22 |  #3
waylandcool wrote in post #15715577 (external link)
Here you go...
To use automatic flash.
Press the mode button until it says ETTL. Put your camera in Av or Tv mode. Take your photo. if the flash is too bright, press the ( button on the back. If it's too dark, press the ) button.
To use manual flash.
Put your camera in manual mode.
Set your shutter speed and aperture to properly expose the background.
Turn on your flash and press the mode button until it says M.
Adjust your flash power by using the ( or ) buttons on the back of the flash until you have the exposure you want.
Easy. I use manual mode 99% of the time.
My photography website!PHOCAL PHOTOGRAPHY (external link)
clarence
Mar 15, 2013 06:56 |  #4
Tiberius wrote in post #15717136 (external link)
Press the mode button until it says ETTL. Put your camera in Av...
-1
With a dark background, in Av mode the camera will try to select a very long shutter speed to try to expose even a midnight sky to midlevel.
ETTL may properly expose the subject with the flash, but with that advice, most novices will be frustrated with the 2 second - 30 second exposures that Av mode with flash will give them.
For Sale: 1D, T1i, 800mm, 600mm
5D3, 1D4, 7D, 600/4L, 200/1.8L, Sigmonster 300-800mm, 80-200/2.8L MDP, 28-70/2.8L, 85/1.8, 50/1.4, 12-24mm, (4) 550EXs, (4) WL strobes, PW MiniTT1/FlexTT5s/AC3/A​C9s
LoCo-Photo.com (external link)
JordanH
Joined Sep 2012
Mar 15, 2013 15:32 |  #5
Tutorials that are specific to the 430EXII will probably be more of a feature rundown rather than tutorials on how to get the best results using speedlights in general (any model).
The 430EXII has ETTL-II and High Speed Sync. It also has features for OPTICAL wireless triggering for "off-camera flash" which can be activated with the pop-up flash on your Rebel. This means that it has all the features necessary to learn the fundamentals that will be taught in any speedlight tutorial.
The only thing it doesn't have worth mentioning is built-in RADIO triggering, but you won't need that at this stage.
Using speedlights well is VERY situation dependent, so manuals won't get you any further than your camera manual teaches you to be a good photographer. Many of the fundamentals for getting good results from your flash actually apply to all lighting.
Good places for tutorials on lighting in general and specifically with speedlights can be found here:
http://www.youtube.com​/user/adoramaTV (external link)
http://www.youtube.com​/user/BHPhotoVideoProA​udio (external link)
http://www.youtube.com​/user/kelbymediagroup (external link)
There's literally hundreds of hours of tutorials amongst those channels, but you'll have to search through to find ones specific to lighting. If you're willing to invest the time it's all there. Experimentation based on what you learn there will also go a long way.
Good luck and have fun!
60D | Canon18-135mm/f3.5-5.6 | Tokina11-16mm/f2.8 | Sigma30mm/f1.4 | YN622Cs | YN568EXs | 430EXII | CS6 | LR4 | Macs
drvnbysound
Mar 15, 2013 16:49 |  #6
I have to agree with clarence here... I know [If I'm using a 430/580 flash in my hotshoe] I'm much more likely to set my flash to ETTL and my camera to manual mode.
That said, I try to shoot with off-camera flash as much as possible, in which case the flashes are in manual mode as well.
I use manual exposure settings on the copy machine
..::Gear Listing::.. --==Feedback==--
...A few umbrella brackets I own...
drvnbysound
Mar 15, 2013 16:51 |  #7
JordanH wrote in post #15718890 (external link)
I didn't think optical triggering was available via the XTi ?? I thought that capability started with the T3i (in the Rebel line)...
inkista
Mar 15, 2013 18:51 as a reply to  @ drvnbysound's post |  #8
I'd start with Neil van Niekerk's Tangents blog/website (external link). Once on-camera bouncing starts to pall, then hit David Hobby's Strobist blog (external link).
I'm a woman. I shoot with a Fuji X100T, Panasonic GX-7, Canon 5DmkII, and 50D. flickr stream (external link)
JordanH
Joined Sep 2012
Mar 16, 2013 00:23 |  #9
drvnbysound wrote in post #15719179 (external link)
Hmm... :o
Tiberius
Mar 16, 2013 06:26 |  #10
clarence wrote in post #15717388 (external link)
-1
Ah, my bad.
Just goes to show how often I use ETTL, don't it?
I knew that one of either Av or Tv would try to balance the ambient. OP, use Tv, not Av.
drvnbysound
Mar 16, 2013 08:33 |  #11
Tiberius wrote in post #15720738 (external link)
Ah, my bad.
You run into problems with Tv, when you want to control DOF yourself.
This is why I shoot with the camera in manual... using the aperture of my choosing to control DOF, and the shutter speed of my choosing to control the amount of ambient light I want to allow.
waylandcool
Gallery: 6 photos
Apr 09, 2013 15:15 |  #12
I subscribed to those channels and I'll start looking through them. Thanks for the info.
2,525 views & 0 likes for this thread, 7 members have posted to it.
1605 guests, 139 members online
