Thread started 15 Mar 2013 (Friday) 20:14
5D MKIII - How Do I Set It To Back Button Focus?
Michelle ­ Brooks ­ Photography
Joined Sep 2009
Mar 15, 2013 20:14 |  #1
Finally (!!!) got the 5D MKIII today :D For the life of me I can't remember how I set the back button focus on my MKII but maybe it's a totally different way. I'm reading the manual but sure would appreciate a quick how-to. Thanks!
Michelle Brooks Photography (external link) | Flickr (external link) | Facebook (external link) | Twitter (external link)
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Mar 15, 2013 20:16 |  #2
Assuming that they set up the CF settings like the 7D, there is a CF setting that shows you a picture of the camera with all the different buttons down the right side, you would use that to assign each control and what it does.
Cassie
Gallery: 296 photos
Mar 15, 2013 20:27 |  #3
Camera icon with the meter, second menu, custom control.
http://thompson-photo.smugmug.com/ (external link)
https://instagram.com/​vegaquarium (external link)
Canon R
*EF 40 2.8*EF 50L*EF 135L*RF 50 1.8 STM* RF 24-105 F4 :D
430 EX II
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Mar 15, 2013 20:39 |  #4
Step by step:
Menu;
Spin little dial until you highlight the 5th Icon to the right,
Spin the big dial down to select custom controls, press set.
There is a bunch you can configure here, but to finish up quickly;
Highlight the first icon, (this is supposed to be a picture of the shutter button) press set
Spin big dial to select the 2nd icon in, for "Metering Start", press set.
Spin big dial to go down one icon to the AF On button, press set.
Select 1st Icon for AF, press SET.
CDS' HOT LINKS
Joined Sep 2009
Mar 16, 2013 05:24 |  #5
Thanks guys, especially you, Jake, for those step-by-steps! It seems the grip must be a little wider or something on the MKIII because it feels like I need to stretch my finger a little more to get to the AF-On button. Can it be put to the * button instead?
Houston1863
Mar 16, 2013 05:58 |  #6
Michelle Brooks Photography wrote in post #15720684 (external link)
Yes you can re-assign the * button Michelle
1. Select Custom Controls from your menu
2. Using the Quick Control dial, scroll down to the * icon - you'll see the * button light up on the camera diagram
3. Press SET
4. Use the Quick Control Dial again to scroll to AF ( Metering and AF start )
5. Press SET
6. Press Menu Button to EXIT
You may now wish to scroll upwards to re-assign the AF-ON button if you so wish.
Hope this helps :)
2x5D3, 16-35L, 24-70L, 70-200/2.8L IS,15 FE, 50L,100L, 2x580EXII, 1x430Exll, Fuji X10, YN-622Cs, Manfrotto Neotec legs, various bits and pieces, my Apples ( 2 living MacBook Pro, 1 dormant PowerBook G4 ), bags and bits of Think Tank stuff
www.picture-u.net (external link)
www.picturing-u.blogspot.com (external link)
Joined Sep 2009
Mar 16, 2013 11:45 |  #7
Houston1863 wrote in post #15720713 (external link)
3. Press SET
5. Press SET
Hope this helps :)
Done! Thanks so much!
amfoto1
Mar 16, 2013 11:54 |  #8
3. Press SET
5. Press SET
Hope this helps :)
In addition, you'll probably also want to set the AF On button to perform AE Lock (which the * button used to do, before you re-assigned it per the above instructions). Otherwise you won't have access to AE Lock and will have BBF on both of the buttons: AF On and *.
Joined Sep 2009
Mar 16, 2013 12:15 |  #9
amfoto1 wrote in post #15721406 (external link)
Also done! Thanks!
John ­ from ­ PA
Joined May 2003
Mar 16, 2013 13:13 |  #10
I found the article at http://neilvn.com …utton-focus-canon-camera/ (external link) to be helpful.
Joined Sep 2009
Mar 16, 2013 13:49 |  #11
John from PA wrote in post #15721590 (external link)
Nice write up! Thanks for sharing!
7,699 views & 0 likes for this thread, 7 members have posted to it.
1596 guests, 137 members online
