I currently have Adobe CS6 with Adobe Bridge. I'm thinking about giving Lightroom a go as I don't really like using Bridge to organise my files. Is Lightroom any better in this regard?
Mar 15, 2013 21:47 | #1 I currently have Adobe CS6 with Adobe Bridge. I'm thinking about giving Lightroom a go as I don't really like using Bridge to organise my files. Is Lightroom any better in this regard?
CyberDyneSystems Admin (type T-2000) More info | Mar 15, 2013 21:55 | #2 If it's just for organizing, you might want to consider GEAR LIST
Mar 15, 2013 22:33 | #3 Thanks, Just had a good look at all the videos on Adobes site and it seems very similar to Bridge so probably not what I'm after, as for editing I don't think it offers anything CS6 doesn't. I'll check out ACDsee 15.
DThompson Goldmember 4,062 posts Likes: 422 Joined Feb 2008 Location: Georgetown, Ky More info | Mar 15, 2013 23:04 | #4 As far as organizing files the only advantage LR has over Bridge is the ability to see files on off-line drives. Dennis
Bob_A Cream of the Crop More info | Mar 15, 2013 23:17 | #5 Lightroom is not even close to being the same as Bridge. The following site gives a very good explanation: Bob
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Mar 16, 2013 00:59 | #6 One feature which is truly uniquely powerful about LR is the fact that you can take ANY COLLECTION of random photos and put them into a Slide Show without moving them out of their original folder. And the same photo can belong to more than one Slide show. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | Mar 16, 2013 04:58 | #7 While it is true that the Raw editing and converting side of LR is virtually identical to the parallel version of ACR, LR has more convenient batch printing and better soft proofing. And in another year it will be a lot cheaper to upgrade to LR5 than to PSCS7. Elie / אלי
agb Member 160 posts Joined Oct 2010 Location: Cleveland Qld Australia More info | Mar 16, 2013 05:49 | #8 CyberDyneSystems wrote in post #15720049 If it's just for organizing, you might want to consider ACDsee 15 In either case, there are free trials and downloads. What one works is so much a matter of taste and experience. Example: I for one don't care much for Lightroom, and yet it is probably the most popular 3rd party RAW converter and organizing tool on the market. Care to tell us why you don't much care for Lightroom?
BigAl007 Cream of the Crop 8,120 posts Gallery: 556 photos Best ofs: 1 Likes: 1682 Joined Dec 2010 Location: Repps cum Bastwick, Gt Yarmouth, Norfolk, UK. More info | Mar 16, 2013 05:57 | #9 The most important thing with any DAM system is to properly embrace it to get the best from it. From an Adobe point of view if you are using more parts of the CS suite than just ACR/PS then you will probably need to carry on using Bridge for at least part of your work. If you are just (or mostly just) a photographer then LR has a shed load of advantages over Bridge/ACR/PS. Yes the RAW editor has exactly the same tools, but the fact that it is fully integrated is a big benefit. You can move from sorting images in the Libary modual to editing by simply hitting a single key shortcut (D), or and this is not one I had thought of before you can go stright to the crop tool by hitting R as in many cases the shortcut keys are the same in all the modules.
DThompson Goldmember 4,062 posts Likes: 422 Joined Feb 2008 Location: Georgetown, Ky More info | Mar 16, 2013 07:43 | #10 Wilt wrote in post #15720423 One feature which is truly uniquely powerful about LR is the fact that you can take ANY COLLECTION of random photos and put them into a Slide Show without moving them out of their original folder. And the same photo can belong to more than one Slide show. For example, an photo of a Model T at the Golden Gate Bridge could belong to a slide collection of 'classic cars', to 'scenic tourist spots', and 'San Francisco' slide shows. You can do the same in Bridge. The only limitation is the files have to be on a on-line drive in Bridge. Dennis
Bob_A Cream of the Crop More info | Mar 16, 2013 14:01 | #11 On top of what has already been said, you can create a ton of different recipes for processing the image using Virtual Copy in LR, without ever having to store an additional file on your hard-drive. The same goes for Soft Proofing ... you can create soft proof recipes for different papers and outputs, and since they are also virtual copies, no files need to be created. Bob
5iftymm Member 121 posts Joined Aug 2012 Location: Seattle More info | Mar 16, 2013 14:30 | #12 LR will save you a tons of HD space vs PS. When you make edits in PS you then have to export them as a JPG or TIFF or something and then store them on your HD which takes up a ton of space, especially if you are duplicating layers etc. Camera + Lens
DThompson Goldmember 4,062 posts Likes: 422 Joined Feb 2008 Location: Georgetown, Ky More info | Mar 16, 2013 15:10 | #13 Bob_A wrote in post #15721706 Before Process version 2012 and some of the newer higher DR cameras I used to use layers to improve shadow and highlight areas but now I find the shadows/highlights sliders in LR or ACR do most of what I need. Process 2012 and the new sliders in ACR work so much better. I can do so much more in ACR now that trips into PS are getting rarer. Bob_A wrote in post #15721706 On top of what has already been said, you can create a ton of different recipes for processing the image using Virtual Copy in LR, without ever having to store an additional file on your hard-drive. 5ifty mm wrote in post #15721778 LR will save you a tons of HD space vs PS. When you make edits in PS you then have to export them as a JPG or TIFF or something and then store them on your HD which takes up a ton of space, especially if you are duplicating layers etc. LR uses non destructive editing and creates kb's of text info on what the image should look like. You can create tons of different versions of the same photo with different looks without taking up any more HD space and without affecting the original file. That way you only have to create another file like a JPG or TIFF if you need to use it somewhere specific and don't have to keep it on your HD. Once you have uploaded it or burned it or whatever purpose you exported it for, you can delete that JPEG or TIFF and clear the HD space because you can just create another one out of LR at any time. You can do the same with Snapshots in ACR. You can create several different versions and the info is saved in the xmp file. Export, upload, and delete the jpeg/tiff just like in LR. Go to Snapshots and make another if the need arises. Dennis
Bob_A Cream of the Crop More info | Mar 16, 2013 15:38 | #14 D Thompson wrote in post #15721890 You can do the same with Snapshots in ACR. You can create several different versions and the info is saved in the xmp file. Export, upload, and delete the jpeg/tiff just like in LR. Go to Snapshots and make another if the need arises.
Bob
BigAl007 Cream of the Crop 8,120 posts Gallery: 556 photos Best ofs: 1 Likes: 1682 Joined Dec 2010 Location: Repps cum Bastwick, Gt Yarmouth, Norfolk, UK. More info | Mar 16, 2013 17:35 | #15 Snapshots are fine, you can do them in LR too, but they are nowhere near as useful as Virtual Copies. You can only see one snapshot at a time, where with VC's you can "see" all of them all of the time. You can also make VC's from any of the supported file types. So if you had to send an image out to PS to do some serious pixel bending, that's fine it then comes back into the LR catalogue where you can produce VC's for softproofing/output to several different devices including custom crops. Or even do a B&W conversion from the PSD rather than having to have various different PSD files for such variations.
| Latest registered member is semonsters 1037 guests, 107 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
