Thread started 16 Mar 2013 (Saturday) 12:26
Locking focus on 5D3?
tvphotog
Mar 16, 2013 12:26 |  #1
I'm using a tripod with a 24-105 lens. I want to take panoramas with a shot to the left and one to the right of the central shot. I can use exposure lock to make sure that each shot is exposed the same.
However, if in the first shot, I tilt the camera down and focus at the hyperfocal distance, lock the focus and return the camera up to the original composition, how can I maintain that focus point in the left and right shots?
Is there a way to lock focus for several shots, just as you can lock exposure in the custom functions?
Jay
Ireland in Word and Image (external link) Jay Ben Images (external link)5D IV | 5DS/R | Sony RX100 V | 24-105L | 100-400 IIL | 16-35 f/2.8 IIL | 24 T/S f /3.5L II | 17 T/S f/4L | 50mm f/1.2L | 35mm f/1.4L | 70-200 f/2.8L II | 580 EX II | 600 EX-RT | Feisol 3441T/Markins Q3T lever QR | Gitzo 3542L Markins Qi20 BV-22 | Gitzo 5561T RRS MH-02
sandpiper
Mar 16, 2013 12:35 |  #2
Just set your focus then switch the lens to MF. The camera then won't alter focus. Alternatively, use back button focus and it will only focus when you push that button.
jocau
Gallery: 11 photos
Joined Mar 2012
Mar 16, 2013 12:36 |  #3
If you don't want your focus to change, switch the lens to manual focus after you have focused or use back button focusing to separate the metering and focusing process.
550D | EF-S 18-55mm F/3.5-5.6 IS | EF 50mm F/1.8 II | EF 70-200mm F/4L IS | Speedlite 580EX II | LumoPro LP180 | Gitzo GT3541XLS | Arca-Swiss Monoball Z1 SP | ONA Bowery (black, non-leather) (external link)
tvphotog
Mar 16, 2013 12:44 |  #4
sandpiper wrote in post #15721508 (external link)
jocau wrote in post #15721512 (external link)
Didn't think of manual focus, too used to AF!
Also, will the back button hold the focus in AF until I hit it again, or just for one shot?
Jay
sandpiper
Mar 16, 2013 12:48 |  #5
tvphotog wrote in post #15721525 (external link)
Yes, the camera focuses normally whilst you press the button but won't focus if you aren't pressing it. So, just set the focus as normal, holding the back button down then, once you release the button, focus is locked until you decide to change it.
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Mar 16, 2013 12:52 |  #6
Avoid all this by turning off "focus" on the shutter button.
Go into custom functions and do as described here;
Step by step:
Menu;
Spin little dial until you highlight the 5th Icon to the right,
Spin the big dial down to select custom controls, press set.
There is a bunch you can configure here, but to finish up quickly;
Highlight the first icon, (this is supposed to be a picture of the shutter button) press set
Spin big dial to select the 2nd icon in, for "Metering Start", press set.
Spin big dial to go down one icon to the AF On button, press set.
Select 1st Icon for AF, press SET.
Now, you will change focus only when you pres the [AF ON] button.
Shutter is left for metering and taking the photo.
If focusing using the [AF ON] button seems unnatural at first, try to get used to it. Give yourself a month or so before giving up on it. It's advantages are considerable in the extra control you have during shooting.
There is a VERY long discussion on the advantages of separating the metering and shutter from the AF control here;
https://photography-on-the.net/forum/showthre​ad.php?t=46965
CDS' HOT LINKS
tvphotog
Mar 16, 2013 13:09 |  #7
CyberDyneSystems wrote in post #15721551 (external link)
Step by step:
Menu;
Thanks for the link, Jake. But let's say I want to keep the focus function on the shutter button. Will using the back focus button override the shutter button focus, and maintain my focus until I push the back button again? Or will shutter button half focus override back button focus?
Jay
sandpiper
Mar 16, 2013 13:14 |  #8
tvphotog wrote in post #15721586 (external link)
Back button AF replaces the shutter button AF, it is either one or the other. You are simply assigning the whole focus operation to another button. Once you set back button focus, the shutter button has nothing more to do with focusing, that is the whole point.
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Mar 16, 2013 13:42 |  #9
It is the point, yes, and how one would get it to lock,...
.. but just to be clear, you can set up a camera so both actions will start auto focus.
...but it won't lock, which is the intended result, so it's no help here.
CDS' HOT LINKS
Yogi ­ Bear
Mar 16, 2013 14:04 |  #10
Yes, shutter button half-press will override whatever you have done with BBF.
Canon EOS 7D | EF-S 17-55mm f/2.8 IS USM | EF-S 55-250mm f/4.0-5.6 IS |
EF 100-400mm f/4.5-5.6L IS USM | 250D | EF-S 10-22 mm f/3.5-4.5 USM | 580 EX II |
1,810 views & 0 likes for this thread, 5 members have posted to it.
1014 guests, 107 members online
