Thread started 16 Mar 2013 (Saturday) 20:18
Raynox DCR-250 On Crop Camera
mnphotos
Joined Aug 2012
Mar 16, 2013 20:18 |  #1
According to Raynox's web site, the DCR-250 is:
"Suitable camera lens: f= 75mm* or longer focal length.
*35mm film equivalent."
Does this mean it will not work on the Canon 40mm pancake lens a crop sensor camera?
LordV
Mar 17, 2013 02:24 |  #2
Depends on what you mean by work. You will get an image but not much magnification- around 0.3:1. The crop sensor does not come into it. It's the actual focal length of the lens that matters and add on diopters like the Raynox work best with longer focal length lenses.
You would be better off using extension tubes with a short lens like a 40mm
Brian V.
Macro Hints and tips
afoton
Joined Apr 2012
Mar 17, 2013 03:58 |  #3
With a diopter like Raynox, you can get some vignetting if you use a too wide lens.
kponds
Joined Oct 2012
Mar 17, 2013 14:52 |  #4
Well, let's run a test! brb.
kponds
Joined Oct 2012
Mar 17, 2013 15:19 |  #5
All images are uncropped, and have had the lightroom preset "Zeroed" applied.
My AAs ran out after the first shot, so I had to convert to using the pop-up flash. So, the lighting and shadows are horrible. The purpose of these images is to show magnification only anyway, so it shouldn't matter.
Here is the 40mm at it's minimum focusing distance with no Raynox:
IMAGE: http://i.imgur.com/HL5afPt.jpg
Then, here it is with the Raynox, also at it's MFD:
IMAGE: http://i.imgur.com/HqX5GpV.jpg
So it does magnify a little, and you could probably get some good close ups (but not "macro") with this if you really wanted.
But it really begs to be used on a telephoto. For comparison, I mounted it on the 55-250 at 250mm:
IMAGE: http://i.imgur.com/dxxJe4F.jpg
More practical is the ~120mm range, where it gives about a 1:1 image.
So it's pretty expected per what the math says. A good bit closer but not quite "macro". I do get 1:1 with the 40mm on extension tubes (didn't get a test shot unfortunately).
I guess my black velvet and acrylic setup is not the best test for vignetting. But I don't notice any through the viewfinder. The 40mm has a tiny front element, and it would baffle me if there were any.
mnphotos
Joined Aug 2012
Mar 17, 2013 19:09 |  #6
Thanks for the test shots. It looks like it's not quite what I'm looking for. I did read a blog or forum somewhere that said it worked fine on a the 40mm lens so that's why I bought it. I can't seem to find the link anymore. I guess I'll just send it back to B&H. I haven't actually received it yet. It's in transit due to be delivered tomorrow, well maybe anyway since we are under a blizzard warning until Tuesday morning.
EDIT: I just checked and it will fit on my Tamron 70-300 so maybe I'll try it out and see how it works.
kponds
Joined Oct 2012
Mar 17, 2013 19:29 |  #7
It should work great on your 70-300 OR your 90mm macro.
mnphotos
Joined Aug 2012
Mar 18, 2013 09:17 as a reply to  @ kponds's post |  #8
Here's a shot done with the 40mm pancake lens and the Raynox.
http://www.flickr.com/​photos/i9mark/74576957​42/ (external link)
Maybe it will work after all.
3,345 views & 0 likes for this thread, 4 members have posted to it.
1061 guests, 101 members online
