Boggy wrote:
Thanks for the link.
Pixel dimension still reads 3072x2048, just wanted to be able to upload at 300 dpi rather than create an action to resample open images as I do at the moment.
Just curious if CS had a way of doing this? And to make sure I had not missed or changed somthing.
Cheers
Shaun
Dear Shaun,
The dpi tag in an image file is of no importance when uploading. It changes neither the quality of the image nor its size. Sooner or later you have to realize the full significance of the dpi tag in image files. It is meaningless. When you want to know how how the pixels are spread out in a "rendered" image (i.e., a real image that you can see as opposed to a virtual image which is just data in a file), then all you have to do to obtain the actual dpi is divide the number of pixels (width or height), by the physical size of the image (width or height) and you've got it. The number stored in the file is meaningless.
