Thread started 17 Mar 2013 (Sunday) 05:14
5D3 and King Pixel Flash Trigger
Tommi ­ B
Joined Jul 2012
Mar 17, 2013 05:14 |  #1
Hi,
anyone tried to use the King Pixel E-TTL Flash Trigger on a 5D3, together with Canon and Metz flashes?
regards
Tommi Bernhardt
sportmode
Joined Nov 2010
Mar 17, 2013 09:13 |  #2
Works fine for me with my 580EXII.
5D Mark III, 6D, EOS-M 22mm f/2 | 24-70mm f/2.8L II | 50mm f1.4 | 100L | 70-200mm f/2.8L IS II | Rokinon 8mm Fisheye
Tommi ­ B
Joined Jul 2012
Mar 18, 2013 09:17 |  #3
Thanks for your answer!
Maybe anyone with a Metz?
regards
vk2gwk
Gallery: 267 photos
Mar 19, 2013 04:09 |  #4
Bump.... I am also interested in this trigger set. Does the e-TTL really works?
What is the effective range. Especially out doors the IR comms of the master-slave set up with my current speedlights doesn't work well. So I am looking at something effective for on the beach or out in the fields.
My name is Henk. and I believe "It is all in the eye of the beholder....."
Image Editing is allowed. Please explain what you did!
5D MkIV 5DMkIII, 50D, 24-105/1:4L IS USM + 100-400/4-5.6L IS USM + 50mm 1.4 USM + Tamron 70-200mm F/2.8 VC + Sigma 150-600mm Sports + 580EXII + 430EX + YN568EXII, triggers, reflectors, umbrellas and some more bits and pieces...
Photos on: Flickr! (external link) and on my own web site. (external link)
C.david
Joined Apr 2011
Mar 19, 2013 07:06 |  #5
vk2gwk wrote in post #15731089 (external link)
Worked well with my 7D in a gymnasium with both 70' from camera. I was able to adjust both right from camera. I believe, haven't tried yet, with the optioning of group from the Kings you will be able to control each flash independently. AGAIN…I haven't tried yet! They are a good starting point to get familiar with remotes.
C.
sportmode
Joined Nov 2010
Mar 19, 2013 10:28 as a reply to  @ C.david's post |  #6
My only complaint about the Pixel King is that rather than remembering the last setting, if you power cycle the transmitter, it resets back to E-TTL, HSS and either 24mm or 50mm (I forget). I have to keep remembering to check that whenever I power-on.
870 views & 0 likes for this thread
Latest registered member is saurav
987 guests, 229 members online
