Thread started 17 Mar 2013 (Sunday) 13:00
Optical Slave Flash Trigger Unit with 650d
jcdavo
Joined Jul 2012
Mar 17, 2013 13:00 |  #1
i have a canon 650d and am trying to trigger my vivitar 283 (old but good)with an optical slave as an off camera flash (as im scared to try it on the camera it case it blows the camera} the vivitar does go off but when i check the pic it has not fired at the right time.
I have tried different shutter speeds (very slow to fast) and have tried shooting in manual focus,in case it was from the double flash for focusing in auto. Any help would be appreciated.
thanks john
maverick75
Joined May 2012
Mar 17, 2013 13:04 |  #2
are you getting black bands? what exact shutter speeds are you using? hows your flash menu setup?
might be as simple as a sync speed issue or you might just have a crappy slave sensor. Make sure the sensor can see the flash from the camera.
nes_matt
Mar 17, 2013 13:07 |  #3
If you are triggering it with the onboard flash, it is firing on the ttl pre-flash.
and you should be scared of putting on a modern camera I believe. Definitely verify the trigger voltage before trying it.
Canon 6D & Rebel T1i | Tokina 11-16 F2.8 | Sigma 18-50mm F2.8 EX DC Macro | Nifty-Fifty |85mm f1.8 | Canon 24-105 F4 | Sigma 70-200mm f/2.8 EX DG OS HSM
Flickr photo stream (external link)
Portfolio (external link)
Facebook Page (external link)
jcdavo
Joined Jul 2012
Mar 17, 2013 13:15 as a reply to  @ nes_matt's post |  #4
it is firing but not in sync i think
Ps no black lines
jcdavo
Joined Jul 2012
Mar 17, 2013 13:28 as a reply to  @ jcdavo's post |  #5
how do i sink
oldvultureface
Gallery: 85 photos
Mar 17, 2013 13:57 as a reply to  @ jcdavo's post |  #6
Try this. Press the flash exposure lock button (*). The on-board and 283 will both fire with the pre-flash. Wait for the 283 to recharge. Take the picture. This assumes you're not in wireless mode.
jcdavo
Joined Jul 2012
Mar 17, 2013 14:05 as a reply to  @ oldvultureface's post |  #7
but im shooting in full manual so there is no preflash for exposer
maverick75
Joined May 2012
Mar 17, 2013 14:16 |  #8
Just forget the optical slave and pickup radio triggers, it will make your life way easier.
dedsen
Mar 17, 2013 18:31 |  #9
jcdavo wrote in post #15725035 (external link)
Your talking the camera is in manual mode.
OVF is referring to your popup flash being in eTTL mode and issuing a preflash. Some Canon cameras allow your to place the popup in manual mode also and eliminate the preflash, but your camera is not one of them. By doing what OVF suggested you wil force the preflash to fire and your flash will fire also, then wait for the flash to recharge and take the picture. The popup will not preflash again and your optical slave will fire in sync with the camera.
But forget all this. Buy a set of wireless triggers for about $30 and some change like maverick suggests and get on with it. Optical triggering with a popup flash is going to drive you nuts.
nes_matt
Mar 17, 2013 21:01 |  #10
dedsen wrote in post #15725897 (external link)
exactly.
msowsun
"approx 8mm"
Gallery: 18 photos
Mar 18, 2013 11:08 |  #11
The 650D/T4i has a manual flash option for the built-in flash. Just go into the flash menu and select "Manual Flash" instead of "E-TTL II". The pop-up flash will then fire without a pre-flash and your optical slave will fire correctly in sync.
Check out page 217 of the 650D/T4i manual.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/03/3/LQ_641352.jpg
Image hosted by forum (641352) © msowsun [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/03/3/LQ_641353.jpg
Image hosted by forum (641353) © msowsun [SHARE LINK]
jcdavo
Joined Jul 2012
Mar 18, 2013 16:36 as a reply to  @ msowsun's post |  #12
thanks for all the replys
2,561 views & 0 likes for this thread, 6 members have posted to it.
1399 guests, 142 members online
