Thread started 18 Mar 2013 (Monday) 15:12
580EXII AF Assist beam without Firing Flash
Michelle ­ Brooks ­ Photography
Joined Sep 2009
Mar 18, 2013 15:12 |  #1
Hey guys; I've read that it's possible to set my 5dMKII camera settings so that my 580EXII when on camera will not fire the flash but still use the AF Assist beam; my question is, if I have a Pockey Wizard on my camera to fire OCF, will THAT still work? Seems like it would but I don't want to find out the hard way it won't. Thanks!
Michelle Brooks Photography (external link) | Flickr (external link) | Facebook (external link) | Twitter (external link)
FiveRings
Mar 18, 2013 21:05 |  #2
It depends on which PocketWizard you have on there, but the basic units that don't do TTL will not trigger the AF assist beam. If you have the flex units that support TTL, then AF assist should work.
facebook (external link)::500px (external link)
I love photography.
Joined Sep 2009
Mar 18, 2013 21:12 |  #3
I have the PW PLUSIIs
klr.b
Mar 18, 2013 21:54 |  #4
How do you have the PW Plus II's connected? Through the camera's PC port?
gordon
Gear and Feedback
Joined Sep 2009
Mar 19, 2013 04:00 |  #5
klr.b wrote in post #15730404 (external link)
Yes.
Tiberius
Mar 19, 2013 05:38 |  #6
I doubt the PC port will get the flashes to trigger the Assist beam. The PC port just has a "Flash fire now!" signal.
My photography website!PHOCAL PHOTOGRAPHY (external link)
Curtis ­ N
Master Flasher
Mar 19, 2013 07:38 |  #7
That's correct. You can't activate the AF Assist light with the PC socket, even if the flash was connected to it directly. The flash needs to be on the hotshoe, or connected to the hotshoe via TTL cord with all six conductors.
To answer the first part of your question - Some Canon bodies have a custom function to make the flash not fire. However, I don't see that option on the 5D Mk II.
Joined Sep 2009
Mar 19, 2013 12:22 |  #8
Maybe I'm misunderstanding, but I have my flash in the hotshoe, set to not fire, with the PW connected to the camera's PC socket.
Curtis ­ N
Master Flasher
Mar 19, 2013 14:04 |  #9
With the flash in the hotshoe, the AF Assist beam will illuminate when needed, if you're using One Shot AF mode (not AI Servo). However, as far as I can tell you can't prevent said flash from firing when you take a shot with the 5D Mk II (The option to prevent the flash from firing is available on some other Canon bodies).
The PC socket, and whatever you have plugged into it, has no bearing on the above paragraph. You will activate whatever is plugged into the PC socket when you take a shot.
Joined Sep 2009
Mar 19, 2013 14:17 |  #10
Curtis N wrote in post #15732698 (external link)
Ok Thanks! {btw, just upgraded to the MKIII! Her name is Roxy :cool: }
Curtis ­ N
Master Flasher
Mar 19, 2013 14:23 |  #11
Ok so now that we have established the technical limitations, here is a practical solution: Turn the flash head around backwards and set it at 1/128 power. The AF Assist will work fine that way, without adding light to your shot.
drvnbysound
Mar 19, 2013 14:25 |  #12
Curtis,
If the option isn't available via the 5D MKII menu, can't you just disable the master from firing via the back of the flash?
A la, top of page 2 here: http://www.learn.usa.c​anon.com …LC_580EXII_Quic​kGuide.pdf (external link)
Or page 39 of the 580EX II manual: http://gdlp01.c-wss.com …dlite580exii-en-es-fr.pdf (external link)
FWIW, the option is available via camera menu on my 50D.
I use manual exposure settings on the copy machine
..::Gear Listing::.. --==Feedback==--
...A few umbrella brackets I own...
Curtis ­ N
Master Flasher
Mar 19, 2013 14:40 |  #13
I had not considered the Master mode/Master Off option. I would point out that it still fires a command flash during the exposure, so she might still want to turn the head around backwards.
klr.b
Mar 19, 2013 22:42 |  #14
Curtis N wrote in post #15731343 (external link)
<snip>
I had no idea the 5DII couldn't disable flash firing. Both of my cameras could disable firing so I could just use AF assist.
I dug around in the 5DII's manual and on page 105, the second footnote at the bottom says:
With an EX-series Speedlite not settable with the camera, only [Flash exp. comp], [E-TTL II], and [Flash firing] are settable for [Flash function settings].
(For some EX-series Speedlites, [Shutter sync.] is also settable.)
Why would a 580ex have an option for Flash Firing, but not a 580exII? :confused:
gordon
Gear and Feedback
apersson850
Obviously it's a good thing
Gallery: 35 photos
Mar 20, 2013 16:12 as a reply to  @ klr.b's post |  #15
Of course it can, and so can the 5D Mark II. Curtis was looking among the custom functions for this, but more and more flash related functions have moved into the flash control menu, something which started with the 1D Mark III, and has become more elaborate since then.
So the setting for disabling the flash, but keeping the AF assist beam, is under the flash control menu. Controlling the AF assist beam itself may still be in a custom function in the 5D Mark II, though.
Anders
5,050 views & 0 likes for this thread, 9 members have posted to it.
1596 guests, 137 members online
