Thread started 18 Mar 2013 (Monday) 23:05
The power of shooting RAW....
jra
Mar 18, 2013 23:05 |  #1
I know that many of you already know and understand the power of shooting in RAW but I just wanted to show it firsthand. This is a fun photo I took of a youth basketball team where my lighting did not fire properly......it was obviously severely underexposed (my camera actually fired twice as I had it in continuous shooting mode so I did capture the photo with lights a split second before....the lights didn't have time to recycle before the second shot). Anyhow, out of curiosity alone, I wanted to see how much detail I would be able to recover in this shot.....and I was quite surprised. I will admit that it's not all that pretty and it does have plenty of noise along with poor lighting quality (only the gym lights).....but I was still amazed at the level of detail and color that still existed in such a poorly exposed photo, especially in the shadow areas. The first pic is as it appeared SOOC.....the second is my edit in an attempt to see just how well I could rescue it. Keep in mind, I'm using a 1DsMkII.....a great camera but it's quite long in the tooth as compared to what's out there now.
IMAGE: http://i65.photobucket.com/albums/h223/jra2212/YD1V9408_1.jpg
IMAGE: http://i65.photobucket.com/albums/h223/jra2212/YD1V9408.jpg
joshhuntnm
Mar 18, 2013 23:18 |  #2
great example. good work.
Josh
Las Cruces Wedding Photography (external link)
Las Cruces, NM Wedding Photographer (external link)
www.joshhunt.com (external link)
http://www.lascruceswe​bdesign.net/ (external link)
tonylong
...winded
Gallery: 60 photos
Mar 18, 2013 23:20 |  #3
Pretty cool, you might want to post that in our RAW Conversion Thread!
If you haven't checked out the thread, read the thread Intro for our "guidelines", check out some examples, and jump in!
Tony
tzalman
Fatal attraction.
Mar 19, 2013 06:22 |  #4
The thing that a lot of people don't realize is that technically there is no bottom to the dynamic range of a CMOS sensor. DR is defined as having a bottom limit that is determined by the point where noise obscures photo detail; in other words, where the noise becomes objectionable. That's a kind of loose concept, one man's objectionable is another man's recoverable. (The DxO Mark web site, in an attempt to set a mathematical definition that can be used to compare cameras, defines it as when the signal to noise ratio is 1, but that mathematical construct is often out of step with the real world.) The fact is that as long as there is even the tiniest bit of light, even just one photon, the sensor will react by outputting voltage. (Actually, it even outputs a random pixel voltage even in complete darkness, the so called "black noise".) Of course as the input light gets weaker its part of the output is smaller and it is submerged in noise, but it is still there.
Elie / אלי
adza77
Mar 19, 2013 06:31 |  #5
Is this why I've been advised that it's better to err on the underexposed rather than the overexposed side for Digital? Seems to make sense. (IIRC - I think someone said it was the opposite in the film days, but I wouldn't know myself).
Great example though to the OP! Thanks for sharing.
Nearly all men can stand adversity, but if you want to test a man's character, give him power. - Abraham Lincoln
Elfstop
Joined Jun 2012
Mar 19, 2013 06:49 |  #6
Wonder what the finished would have looked like had that started out in jpeg?
BigAl007
Gallery: 556 photos
Mar 19, 2013 07:18 |  #7
Elie I have not really delved into DxO mark but from a general Digital Signal Processing perspective SNR's of 1:20 are not that difficult to deal with as long as the signal you are looking for is well below the Nyquist frequency (The Nyquist frequency is the highest frequency any digital system can represent, and is half of the sampling frequency, so at worst you have 2 samples per cycle), and the noise is truly random. This is the big advantage of using DSP over traditional analogue systems, as you can deal with quite large negative SNR's.
Alan
DunnoWhen
Mar 19, 2013 07:36 |  #8
adza77 wrote in post #15731247 (external link)
Is this why I've been advised that it's better to err on the underexposed rather than the overexposed side for Digital?....
You may want to check out THIS thread.
My wisdom is learned from the experience of others.
katodog
Mar 19, 2013 07:39 |  #9
Elfstop wrote in post #15731269 (external link)
If you had the original file it might not be too bad, but if all you had to work with was the image in this thread you couldn't do much without serious degradation. I'd say that recovering this photo if it were shot in JPG wouldn't be that hard to do if you had the skills.
The only stupid question is the one that goes unasked - Photographers shoot to thrill, not to kill
My Gear- Flickr (external link) - Facebook (external link) - Smoke Photography - - Sound-Activated Paint
tonylong
...winded
Gallery: 60 photos
Mar 19, 2013 07:41 |  #10
Not really, if you value Image Quality then the best thing is to shoot Raw and "push" your exposure a bit "to the right" (check out the "Expose To The Right" (ETTR) method). In general, it's better to get more light, so that you get a better signal-to-noise ratio in those shadows, than less light.
This assumes, though, that you are not getting too much light so that you are "blowing" highlights.
But as the example shows, Raw also gives you "room to play" with the shadows.
The question was asked about how jpegs would handle those shadows. Well, when jpegs are produced in the camera, 8-bit compression and jpeg compression is applied, and unused Raw data is discarded. In the case of highlights and shadows, if they are considered "out of bounds", they will be clipped by the conversion (even if there is some "info" in the Raw data). If someone is curious, go ahead and try, shoot and underexposed scene in Raw+jpeg and compare how much you are able to recover!
Tony
vschapman
Joined Aug 2012
Mar 19, 2013 07:42 |  #11
WOW! Perfect example!
Canon EOS Digital Rebel XTi Gripped | Canon AE-1 Program | Bronica ETRS
EF-S 18-55mm f/3.5-5.6 II - EF 50mm f/1.8 II - EF 75-300mm f/4-5.6 II - EF 35-80mm f/4-5.6 III - Sigma 70-210mm f/4-5.6
- FD-EOS Adapter - Various FD Lenses - Home Darkroom
tonylong
...winded
Gallery: 60 photos
Mar 19, 2013 07:43 |  #12
In fact, go ahead and download the jpeg that the OP posted, and give it a shot, if you think you can get results that approach the Raw recovery, post!
Tony
katodog
Mar 19, 2013 07:52 |  #13
tonylong wrote in post #15731359 (external link)
The image in the post is too small and too compressed, you'd need the OP to convert the RAW to JPG with all the settings at zero, then upload that file.
tonylong
...winded
Gallery: 60 photos
Mar 19, 2013 07:58 |  #14
katodog wrote in post #15731377 (external link)
The point is that the image posted was a jpeg with all the compression applied. The fact that it was resized for the Web, sure, more image was "tossed away", but you can still get a general idea of what you can recover in the shadows.
But if you really question it, take a jpeg that is equally unexposed and see (and post)!
Tony
kirkt
Mar 19, 2013 08:23 |  #15
At the posted size yo could probably print the image and it would be ok. But you can see the dreaded Canon pattern noise that plagues these cameras and limits the ability to get a useable image fro these situations. This striped noise is not random and is large enough that the pattern in which it appears is very distracting and difficult to remove.
Not to take away from the OPs treatment, but this is one issue that Canon need to address to make the these kind of images useable.
kirk
Kirk
9,629 views & 0 likes for this thread, 18 members have posted to it.
1314 guests, 135 members online
