Thread started 20 Mar 2013 (Wednesday) 11:46
Spot metering
dharris
Mar 20, 2013 11:46 |  #1
Question: When I set my meter to spot and my AF to center point, if I decide to change my AF point away from center how will spot meter in react?
In other words if; Photographing a person with my AF point on subjects face will my camera meter off the shirt and not the face area?
Thank you,
Don
gonzogolf
dumb remark memorialized
Gallery: 561 photos
Mar 20, 2013 11:50 |  #2
Your camera likely meters off the center point, not the focus point. Some newer advanced models let you assign the metering point, but most dont.
Snydremark
my very own Lightrules moment
Gallery: 66 photos
Mar 20, 2013 11:50 |  #3
What camera body are you using?
dharris
Mar 20, 2013 11:53 |  #4
Snydremark wrote in post #15736061 (external link)
I use a 5dc and 7d, sorry for not providing that information.
Snydremark
Gallery: 66 photos
Mar 20, 2013 11:58 |  #5
Ok, yeah; on the 7D, at least, the spot meter is only around the center AF point. I'm relatively certain that the same is true for the 5Dc, although, I've never used one.
javig999
Mar 20, 2013 12:01 as a reply to  @ dharris's post |  #6
I know the 7D meters based on the center. There is even a circle that appears when you switch to spot metering. So, yes, it will meter off a person's shirt, etc (especially in portrait orientation). I recently shot a big band rehearsal, and as they were in casual dress, shirt colors varied. Shutter speeds were all over the place. I would spot meter on your subject's face (or preferred body part :)) in Av, note the shutter speed, and switch to Manual. Give yourself a high enough SS so that you can drop a bit for darker portions of the stage/scene, and increase it for hot spots, etc.
Hop this helps...
7D | 8mm 3.5 FE | EF-S 10-22 | EF-S 17-55 2.8 IS | EX DC 30 1.4
EOS R | Samyang 14 2.8 | Sigma 15mm f2.8 DFE | RF 16mm | Art 20/35/50/85 f1.4 | EF 100 f2.8 Macro | EF 135 f2L | EF 70-200 f2.8L IS | Sigma C 150-600
dharris
Mar 20, 2013 12:46 as a reply to  @ javig999's post |  #7
I have been photographing little league baseball players with different results. My subjects change from size and different colored shirts. This is done outdoors and the light continually changes. I shoot with my assistant holding a gobo for me.
This is a step and repeat setting. I have used evaluative metering for the longest time and now actually taking the time to learn how my meter actually works.
I shoot Canon 5dc and 7d
dharris
Mar 20, 2013 13:17 |  #8
Another question; When in manual mode is the meter setting disengaged?
DunnoWhen
Mar 20, 2013 13:31 |  #9
dharris wrote in post #15736374 (external link)
When in manual mode, it might be easier to say that there is no "meter setting". The camera is merely acting as a light meter and does not make any settings. You choose and set the values required. That said, it could be argued that they are "disengaged" when either you change them or you switch from manual mode.:)
My wisdom is learned from the experience of others.
gonzogolf
Gallery: 561 photos
Mar 20, 2013 13:37 |  #10
dharris wrote in post #15736255 (external link)
Shoot manual and meter on the grass. Adjust occasionally based on changing light.
Snydremark
Gallery: 66 photos
Mar 20, 2013 13:57 |  #11
The meter is 'active' in manual mode; this is why you see the needle move around. It's showing you the current reading from whatever the camera is looking at. Whereas, in Av/Tv the camera attempts to auto-center the needle, so the scale there is used to only display how much you want to override the camera's decisions. So, the needle only moves when you dial in some level of exposure compensation (EC).
Think of it like this: If you put your camera in Tv/Av, point it at a given subject, and dial in EC until the needle lines up with the '1' on the scale; or, you put the camera in manual, pointed at the exact same subject, and dial in your aperture/shutter until the needle moves to line up with the '1', both will give you the same exposure.
NewCreation
Gallery: 47 photos
Joined Jan 2013
Mar 20, 2013 14:43 |  #12
gonzogolf wrote in post #15736448 (external link)
+1 to this
My name is Brenda ~Saved by grace, walking by faith
http://brendahoffmanph​otography.com (external link)
Facebook (external link)
delhi
Mar 20, 2013 14:47 |  #13
AF linked Spot metering is only available in 1d-series. You can have Canon to thank for.
To a limited extent, you can use Evaluative metering as it supposed to bias the metering at the AF point location. It is ok if the degree of contrast is not wide.
Vancouver Portrait Photographer (external link)
No toys. Just tools. (external link) :lol:
5d3/1dx AF Guidebook | What AF Points to use for my 5d3/1dx?! (external link)
kouasupra
Mar 20, 2013 16:09 |  #14
gonzogolf wrote in post #15736060 (external link)
Correct. Those camera will meter off the center point in spot metering. If your shooting the outer points. I would recommend using evaluative metering instead.
I know the 1DX can spot meter off any AF points, but I'm not sure about the 5D3's AF system.
Bottom line is use evaluative/matrix metering if not not using center point.
dharris
Mar 20, 2013 19:25 as a reply to  @ kouasupra's post |  #15
Thank you all for the help! Couple folks mentioned metering the grass and go from there. Can you please elaborate why I should meter the grass? Is it due to the nature of brightness of the sun on the grass?
Thank you,
Don
5,166 views & 0 likes for this thread, 22 members have posted to it and it is followed by 2 members.
Spot metering
856 guests, 162 members online
