Hot Bob wrote in post #15738300
I'm shooting horses! Right now I'm lighting with a handheld 16" 30° sports reflector from about 40-50 feet. I actually have enough power but I want to shoot higher frame rate and it would be nice if I could soften the light up a bit too. Maybe a medium silver parabolic panning on a stand. My Speedo 4803 won't even come close. The 1205 recycles much faster at equivalent power settings. Of course the 4803 is pretty old; I wonder if the newer CX models are any faster at recycling?
Bob, I cannot add anything to the recycling speed issues, but want to address your issue of softening the light.
At 40 to 50 feet, I very seriously doubt that you'd see any difference in the "softness" quality of the light if you used even a 60" diameter umbrella. The distance makes that still seem like a small light source.
Think of the sun. In reality, it's about the largest light source available to us. However, it's so far away that it's effectively a point-source of light which is why shadows in sunlight (with no clouds in the sky) are so harsh.
In a portrait studio, it's not unheard of to use a modifier that is as wide as the distance between the face of the modifier and the subject. That's the way that shadows can really be softened.
What you might be able to soften the light to do is to use several sources of light (each pretty darned serious in it own right) spaced over a span of twenty to thirty feet or more. They would all be triggered by radio slaves. If you're in an indoor venue with a white ceiling, you could bounce some of the light.
