Thread started 21 Mar 2013 (Thursday) 22:44
Monochrome in camera Yes or No?
Adamrhh
Joined Mar 2013
Mar 21, 2013 22:44 |  #1
If you want to shoot Monochrome (B&W) Would you have a "better" time taking all your pictures in color then putting them into Lightroom and applying the filter(Even if you had no desire for a colored image) or do you think you achieve more natural black and white from in camera then all you have to do is just tweak the already black and white image? (RAW)
So I guess my question is If you knew you wanted black and white images in the outcome would you set your camera to monochrome or would you just leave it in color then convert it over in editing?
jaomul
Joined Apr 2011
Mar 21, 2013 22:51 |  #2
Always do B+w with software as you can than tweak the colour channels for better b+w photos
Olympus EM5,Nikon d7200,
Olympus 12-50mm, 40-150mm,17mm f2.8,Nikon 50mm F1.8, Tamron 90mm vc, 18-105mmVR, Sigma 18-35 f1.8
Corbeau
Joined Jan 2013
Mar 21, 2013 22:53 |  #3
Leave it in RAW, in its full glory, then convert in LR, playing with the RGB sliders as needed.
If it's an in-camera conversion, you're kinda stuck with what you got.
Look and think before opening the shutter. The heart and mind are the true lens of the camera. -- Yousuf Karsh
Adamrhh
Joined Mar 2013
Mar 21, 2013 22:58 |  #4
Well what I mean under picture style there is monochrome so it's Monochrome RAW so its still a raw photo just black and white already vs it being in raw color
SkipD
Joined Dec 2002
Mar 21, 2013 23:04 |  #5
Adamrhh wrote in post #15741806 (external link)
I don't believe that any RAW image file has the color information missing.
Skip Douglas
aliengin
Joined Mar 2011
Mar 21, 2013 23:05 |  #6
Its the file size and data the image carries. Try this, shoot RAW and convert to BW in any software you have. And shoot monochrome (BW) with camera settings. After that look at the file sizes and the 100% crops. In camera gives better resolution but less tweaking, RAW conversion loses some of the resolution but gives better tweaking.
Ali Engin Photography (external link)
jaomul
Joined Apr 2011
Mar 21, 2013 23:09 |  #7
Your canon picture style (monochrome or others) are only recognised in canons dpp, so your raw file will open in dpp in monochrome but can be changed back to colour,the jpeg will remain black and white. If you select mono in camera and open the raw file in any other converter it will open as a colour file
TSchrief
Joined Aug 2012
Mar 21, 2013 23:49 |  #8
jaomul wrote in post #15741838 (external link)
Exactly. Raw is raw, color and all. With Picture Style set to Monochrome and shooting raw, your camera shows you a B&W jpg. The raw file is not affected by Picture Style settings. If you are going to shoot raw, shoot an unadjusted Neutral picture style. You'll get a more accurate histogram. The histogram is generated from the in-camera jpg, which IS affected by picture style.
Motor ­ On
Mar 21, 2013 23:59 |  #9
This.
It's also somewhat handy if I know I'm going to be doing a bunch of work in black and white, to go ahead and turn that picture style on, this will give me the back of the LCD in black and white; this can aid in visualizing things around you in black and white
Website (external link) | Facebook (external link) | Instagram (external link)
Dan ­ Marchant
Gallery: 19 photos
Joined Oct 2011
Mar 22, 2013 02:54 |  #10
Adamrhh wrote in post #15741768 (external link)
..... or do you think you achieve more natural black and white from in camera then all you have to do is just tweak the already black and white image? (RAW)
As pointed out by others, you can't shoot a B&W RAW. The camera style settings such as Monochrome, Landscape etc only affect jpeg files (including the jpeg preview you see on the LCD). Setting the camera to Monochrome will have zero affect on the RAW file and the RAW will be displayed as a colour image when imported into your PP software (unless you use Canon's DPP software).
That fact aside my answer to your actual question is "no". You won't achieve a more natural B&W using the in-camera monochrome settings for exactly the same reason that in camera settings won't give you the best colour images. There are many different ways to process a black and white image. Different images will benefit from different approaches to processing. Lightroom includes 15 different B&W presets that you can select (and of course you can create any number of your own).
Dan Marchant
kalmo
Mar 22, 2013 05:49 |  #11
I do sometimes shoot B&W in Jpg with my own customized picturestyle on my 5Dmk3.
My rule usually is:
Am I being paid for this: Yes = Shoot Raw
No = Shoot Jpg (and SMALL)
I just can't stand having 4gb of party pics etc taking up my HDD space, as I know they will just end up on facebook etc.
Canon 5D mk3
70-200mm f2.8 L IS
24-70mm f2.8 L
Speedlite 580 EX II
Elinchrom Ranger RX AS with 2 A-Heads & Deep Octa
Submariner
Joined May 2012
Mar 22, 2013 07:02 as a reply to  @ kalmo's post |  #12
I want to shoot in JPEG [So I can instantly transfer output to iPad4 and review - to date not seen a way to bring the Raw files into an iPad and then process there! - any ideas as an aside welcome].
If I choose colour neutral in JEPG and later on a PC remove the colour saturation in DPP
It only looks like 80% B&W.
Yet if I choose the picture style Monochrome and in DPP remove all the colour saturation they look much more like 100% B &W . Then they look good.
Can anyone explain this?
And therefore to OP my answer is:-
A) If I KNOW I want JPEGS, then I choose picture style, neutral setting MONOCHROME.
B) If I'm not sure at time of shooting, then colour L size JPEG, and later change in DPP, and then have to run it through Sony's version of DPP to do a second colour saturation removal - all very unsatisfactory!
Plus any tweeking needed in Photoshop elements 9 - as it came free with my new Laptop!
C) if I don't need instant Jpegs ref the iPad4 then I would shoot in RAW , neutral pic style, and use DPP. I don't own Light room sadly no cash for it.
Canon EOS 5DS R, Canon EF 70-200 F2.8 L Mk II IS USM, Canon EF 70-300 F4-5.6 L IS USM, EF 40mm F2.8 STM , RC6 Remote. Canon STE-3 Radio Flash Controller, Canon 600 EX RT x4 , YN 560 MkII x2 ; Bowens GM500PRO x4 , Bowens Remote Control. Bowens Pulsar TX, RX Radio Transmitter and Reciever Cards. Bowens Constant 530 Streamlights 600w x 4 Sold EOS 5D Mk III, 7D, EF 50mm F1.8, 430 EX Mk II, Bowens GM500Rs x4
Anthon
Joined May 2012
Mar 22, 2013 07:29 |  #13
If you want to shoot some B&W photo's, just use Monochrome RAW - that way you could have a represantable preview and still have the advantage of RAW in editing.
You really need color data to get best B&w results in post.
Canon 5D mark II Gripped / 17-40mm f4 L / 24-105mm f4 L / Canon 70-200 f4 L / Samyang 14mm 2.8 AE / Pentax SMC 50mm f1.7 / Pentax SMC 28 2.8 / Canon Speedlite 600ex-rt / Canon Speedlite 580ex II / YN560 II
airfrogusmc
Gallery: 179 photos
Mar 22, 2013 08:20 as a reply to  @ Anthon's post |  #14
Or shoot with one of these. A Leica M Monochrom. Its a lot better than any conversions.;)
BigAl007
Gallery: 556 photos
Mar 22, 2013 11:06 |  #15
Leica M Monochrome and a digital enlarger so that I can expose onto proper B&W photo paper. Actually it would be nice to have a proper monochrome DSLR option, to shoot things that the M system is not so good at, after all they do not have any super telephoto lenses, and a 500-600 mm lens would be great for me.
Alan
6,067 views & 0 likes for this thread, 23 members have posted to it.
1387 guests, 135 members online
