morph2_7 wrote in post #15745426
It'd be great if you share the reg hack technique you found.
Found it myself.
To install DPP without Canon CD (or without older DPP version already installed) just create a new key under HKEY_LOCAL_MACHINE\Software. Name it Canon. Then create another new key under HKEY_LOCAL_MACHINE\Software\Canon. Name it DPP.
For 32-bit (x86) OS: HKEY_LOCAL_MACHINE\SOFTWARE\Canon\DPP
For 64-bit (x64) OS: HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Canon\DPP
The downloaded DPP software update will run without a problem.
To mod, if this trick isn't allowed, please let me know or edit my post.
Yes, that is it. Also, if you search for canon software without CD or similar, you can find what all the registry keys should be named so that you can install DPP, photostich, the EOS utility, etc..
One site that lists the keys is this one. http://www.mydigitallife.info …e-eos-utility-without-cd/
it odesn't quite tell you hot to get to the registry key the way I did or the way shown in the post above, but once you start creating the new folders, you just name them appropriately and everything installs and works perfect.
