Can you C&C a first attempt at Low Key. Just roughly is it close etc?
![]() | HTTP response: NOT FOUND | MIME changed to 'image/gif' | Redirected to error image by FLICKR |
IMG_6019
Dannybegood Goldmember 1,606 posts Likes: 1 Joined Nov 2011 Location: Cambs,UK More info | Mar 26, 2013 10:26 | #1 Can you C&C a first attempt at Low Key. Just roughly is it close etc?
IMG_6019 Danny,
chimpsinties Senior Member 315 posts Likes: 8 Joined Nov 2012 More info | Mar 26, 2013 10:37 | #2 What's the exif on this? IMG_1369 My Flickr
graydragon1 Member 60 posts Likes: 2 Joined Mar 2012 Location: Indianapolis, IN More info | To me, it looks more under-exposed than low-key. If you aren't making mistakes, you're not trying.
gonzogolf dumb remark memorialized More info | Mar 26, 2013 10:49 | #4 Its just underexposed.
Mar 26, 2013 10:54 | #5 If your looking for a end product similar to the shot below you need to change up your methods a bit. Canon EF 70-200 F/4L USM
Mar 26, 2013 11:10 | #6 A big no then, thanks for the comments. must try harder. Danny,
chimpsinties Senior Member 315 posts Likes: 8 Joined Nov 2012 More info | Mar 26, 2013 11:16 | #7 silvrr wrote in post #15757215 If your looking for a end product similar to the shot below you need to change up your methods a bit. 1. Black background and surface for the lens to sit on. Keep the background well away from the flash as it will help control any spill over on to the background. 2. Set your SS and ISO so that a flash w/ out the flash on provide a nearly black frame (the closer to black the better) 3. Add in the flash. For the shot below the flash was actually slightly behind the lens to prevent any further wrap around of the light. 4. Post processing. Drop the black levels, and then some selective editing to bring it the background to all black and/or control some light bleed.
My Flickr
BigLobowski Goldmember More info | Mar 27, 2013 13:56 | #8 chimpsinties wrote in post #15757274 This is basically a spot on description. But No4 is the thing that'll get you out of bind. Get in LightRoom and drop those shadows right down ![]() Hope you don't mind, but since you have image editting checked I took a few seconds (literally) and tweaked your pic in LR to give it more of a "low key" look: eta: playing with lighting to achieve the look is of course the preferred method... ![]() - Ken
| Latest registered member is semonsters 906 guests, 122 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
