FORUMS Photography Talk by Genre Critique Corner
Thread started 26 Mar 2013 (Tuesday) 13:32
First Attempt at Flower Shot
Ceallach62
Joined Jan 2013
Mar 26, 2013 13:32 |  #1
I have no appreciable experience/knowledge with regards to creating a good flower image. Last night I played with my new Kenko tubes and shot some cherry blossoms. I'm looking for whatever guidance/input I can get.
CAMERA: T3i, 18-55mm kit lens (set to 55mm), and a 25mm tube.
TECHNIQUE: ISO 800, f/32, 8/10 sec.
LOCATION: The location was my kitchen using only the available light through the window.
POST: A little PP was done in Lightroom, mostly adjusting sharpness, clarity, and a little increase in the exposure level.
QUESTIONS:
1. RE: Lighting. Considering the blossom was almost touching the lens, what is the best technique to improve lighting?
2. RE: Sharpness/clarity. I used a small aperture to get as much DOF as possible. How can I make it really crisp? If I drop to ISO 100, would the additional exposure time be an issue with a subject this magnified?
3. RE: Composition. I wanted to focus on the center of the flower, and less the pedals. Composition-wise, how did I do? Does this work?
4. RE:PP. Any input? What does it need. I played with B&W and like that potential.
5. Any advice?
Basically, this is my first serious attempt at flowers. How did I do?
Kelly (the masculine version, as nature intended)
Canon 6D | Canon 60D | Sigma 24-105 f/4 Art | Canon EF 100-400mm f/4.5-5.6L IS II USM Lens | Tokina 16-28mm f/2.8 | Tamron SP DI 90mm macro f2.8 |
-->My FlickR (external link)<--
Martin ­ Dixon
Slit-scan project master
Gallery: 59 photos
Joined Sep 2009
Mar 26, 2013 15:01 |  #2
1/ I think you need stronger (slightly harder) light to bring out textures and contrast, but not too much.
2/ You need biggest DOF you can get with macro work unless you venture into focus stacking, which isn't really that difficult - you take more than one image moving the camera a little toward the subject - a slider can help a lot, then you can combine by hand in photoshop or use a program like CombineZP (free). Having said that f32 might be a bit much - try a variety of apertures.
3/ I think composition is pretty good.
4/ possibly local contrast and sharpness increased
5/ Keep going you're doing well even without specialist lenses. always carry an extension tube.
I do like the image, thought it looks slightly soft to me.
flickr (external link) Editing OK (external link) www.slitcam.com (free slit-scan utility) (external link)
Ceallach62
Joined Jan 2013
Mar 26, 2013 15:32 |  #3
Thank you Martin. In regards to lighting, I was at a loss because the blossom was almost touching the lens. So I'm thinking maybe a diffused off-camera flash might work???
Stacking? I'll look into that. Thanks!
Martin Dixon wrote in post #15758182 (external link)
Martin ­ Dixon
Gallery: 59 photos
Joined Sep 2009
Mar 26, 2013 17:57 |  #4
Yes flash will work - can be harsh - I have used aluminium foil to reflect the flash over all sides of the subject. I have found LED lights useful too as you can get them close without burning the subject (or yourself!)
Ceallach62
Joined Jan 2013
Mar 26, 2013 18:57 |  #5
@Martin: Thanks for the tip. Playing with light... this is fun!
@kjonnnn: I like your edit. Looks great! I'll play with it tonight on Lightroom and then get some more blossoms to shoot.
Ceallach62
Joined Jan 2013
Mar 27, 2013 21:12 |  #6
Here is my latest edit...
sssc
Gallery: 32 photos
Mar 27, 2013 22:40 |  #7
Wow that is really looking good to me :)
Keith-EOS R 7D MarkII EOS REBEL T2i 18-55,55-250.85 1/8. 100-400L. 10-22 f/3.5-4.5. 24-105mm f/4L IS,70-200 II,RF 24-105
Ceallach62
Joined Jan 2013
Mar 27, 2013 23:40 |  #8
sssc wrote in post #15763858 (external link)
Thank you for the kind words, Keith
tmoore323
Mar 28, 2013 00:20 |  #9
seems soft to me...
Something similar that I did:
IMAGE: http://farm8.staticflickr.com/7267/7004666029_4171a92984_b.jpg
IMAGE LINK: http://www.flickr.com …/47401703@N06/7​004666029/  (external link)
CherryBlossom-1 (external link) by tmoore323 (external link), on Flickr
Kaotic ­ Lazagna
Joined Feb 2012
Mar 28, 2013 00:27 |  #10
I like the "latest edit."
I wouldn't use such a high f-stop, as someone else said. As for lighting, you can make your own ring light if you have some camping lights laying around. I made one, and it helps out a little (although, if your subject has a glossy surface, the "ring" will definitely be seen.
*sorry for image quality, used my phone*
HTTP response: 403 | MIME changed to 'text/plain'
Canon T2i / 18-55mm kit lens / Sigma 30mm f1.4 / Canon 85mm f1.8 / Canon 100mm f2.8
sssc
Gallery: 32 photos
Mar 28, 2013 00:28 |  #11
The softness works with the colors from what i see.
sssc
Gallery: 32 photos
Mar 28, 2013 00:32 |  #12
Nice shot Tmoore. Kaotic that is pretty cool what you came up with there:)
Kaotic ­ Lazagna
Joined Feb 2012
Mar 28, 2013 00:39 |  #13
sssc wrote in post #15764117 (external link)
Thanks :D
Can't figure out a way to diffuse the LEDs so that there won't be "dots" on glossy surfaces.
Chandler.
Mar 29, 2013 06:29 |  #14
Hit it with an S-curve
IMAGE: http://i.imgur.com/dKrMJb3.jpg
I realize some might think this is overdone, but I like my images crispy.
Sharpness/clarity: you don't need to use ISO 100. At f/32 on an APS-C sensor, you begin to deal with diffraction, which hurts image quality. f/16 (arguably f/11 would probably treat you better, purely speaking. Practically speaking, however, diffraction isn't a huge deal with this image at this size. However, opening up the lens a couple stops would improve image sharpness more than dropping down to ISO 100. The increased exposure time wouldn't matter as long as you have a tripod, use a remote release/timer and there is zero wind. Indoors, you'll be fine with this subject.
Composition: you did fine, the bottom left edge bugs me, so I cropped it out.
Lighting: Flash. See the Macro board.
BTW, Maple Valley isn't a bad place.
There are no rules for good photographs, there are only good photographs. ~ Ansel Adams
1,493 views & 0 likes for this thread
Latest registered member is alpo2k
873 guests, 286 members online
