Will using the Back Button to focus trigger IS on the lens? Thanks
Alan
alanwk Hatchling 7 posts Joined Jun 2011 More info | Mar 26, 2013 15:07 | #1 Will using the Back Button to focus trigger IS on the lens? Thanks
Mar 26, 2013 15:21 | #2 So if I use Back Button Focusing I wont get IS like when I focus with the half press on the shutter button?
BeezPhoto Mostly Lurking 12 posts Joined Mar 2013 More info | Mar 26, 2013 15:24 | #3 correct. You will trigger IS if you half-press the shutter only when IS is enabled on that lens. Canon 50D + 18-55mm f/3.5-5.6 + battery grip
ghpatriot Goldmember 1,310 posts Likes: 7 Joined Jan 2009 Location: Grand Haven, Michigan U.S.S.A. More info | Mar 26, 2013 15:25 | #4 John from PA wrote in post #15758232 No, IS and focusing are two different things. wrong. It will activate IS. 2 x 5D III | 40D | Rokinon 14 2.8 | 35L | 50[B]L | 85IIL | 100 L |135L | 300 f4L | | 24-70L | | 70-200 2.8L II | 2XL |
ghpatriot Goldmember 1,310 posts Likes: 7 Joined Jan 2009 Location: Grand Haven, Michigan U.S.S.A. More info | Mar 26, 2013 15:25 | #5 alanwk wrote in post #15758212 Will using the Back Button to focus trigger IS on the lens? Thanks Alan
shedberg Goldmember 1,122 posts Likes: 1 Joined Mar 2010 Location: Terrace, B.C. Canada More info | Mar 26, 2013 15:27 | #6 I can confirm, when I press the * key for back button focusing, IS is also turned on. My Flickr Page
iTookMyShot Goldmember 1,334 posts Likes: 73 Joined Mar 2006 Location: So Cal, USA More info | Mar 26, 2013 15:31 | #7 True dat... 5D mkIV, 2x)7D mkII, 500 f4L IS mkII, 100-400L IS mkII, 70-200 2.8L IS mkII, 24-70 2.8L mkII, 16-35 2.8L mkIII, 100 2.8L IS, 600EX-RT x4
Another yes. BBF will activate IS (provided the switch on the lens is on).
halitime Goldmember 1,271 posts Likes: 19 Joined Feb 2009 Location: Lantzville B.C. Can. More info | Mar 26, 2013 16:15 | #9 Turns on with back and shutter buttons but there is no point in pressing the shutter button before focusing. Gear List : 1D MK II n,Gripped XSi,70-200 f4,300 f4 IS,Canon 24-105 f4,35 f2 IS,EF 50 1.8 MK I,EF-S 10-22,Canon 1.4 II Extender,Canon 25mm Ext Tube,YN 468/460 II,RF 602's
Hogloff Cream of the Crop 7,606 posts Likes: 416 Joined Apr 2003 Location: British Columbia More info | Mar 26, 2013 16:21 | #10 Permanent banInteresting to see two totally different answers to a simple question. Just goes to show how careful one needs to take information one receives from the Internet.
Nathan Can you repeat the question, please? More info | Mar 26, 2013 16:26 | #11 Back button AF activates IS. You should hear the motor running as soon as you press the back button. Nuance to your question, however, is whether you assign AF-ON to the shutter and AF-Lock to the back button. If AF-ON is assigned to the shutter, then the shutter turns on IS. If no AF function is assigned to the shutter but is assigned to the back button, then only back button will activate IS. halitime wrote in post #15758519 Turns on with back and shutter buttons but there is no point in pressing the shutter button before focusing. Unless you use it for AE lock. Taking photos with a fancy camera does not make me a photographer.
Mar 26, 2013 16:29 | #12 This is what manuals are for. Page "ENG-7," last bullet point on the right: canon wrote: If you set the camera's Custom Function to change the assigned button to operate the AF, the Image Stabilizer will operate when you press the newly assigned AF button. 1D MkIV | 1D MkIII | 550D w/grip & ML| EF 70-200mm f2.8L| EF 24-105mm f4L IS | Canon EF 100-400mm f/4.5-5.6L IS | Samyang 14mm f/2.8 IF ED UMC | 430EXii | EF 50mm f1.8
apersson850 Obviously it's a good thing More info | Mar 26, 2013 17:15 | #13 Hogloff wrote in post #15758551 Just goes to show how careful one needs to take information one receives from the Internet. And how little some camera owners know about their camera. Anders
CyberDyneSystems Admin (type T-2000) More info | Mar 26, 2013 17:19 | #14 Hogloff wrote in post #15758551 Interesting to see two (make that THREE!) totally different answers to a simple question. Just goes to show how careful one needs to take information one receives from the Internet. It is a little daunting?! GEAR LIST
CyberDyneSystems Admin (type T-2000) More info | Mar 26, 2013 17:20 | #15 waterrockets wrote in post #15758585 This is what manuals are for. .. It's also what internet forums are for GEAR LIST
| Latest registered member is Thunderstream 1006 guests, 105 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
