Thread started 27 Mar 2013 (Wednesday) 06:33
EF 24-70 or EF-S 17-55 help
vali003
Mar 27, 2013 06:33 |  #1
Hi ,I am in a bit of dillema ,what to buy EF24-70 F4 L IS or EF-S 17-55 F2.8 IS , my work is out side , fishing trips . That will go on a EOS 60 D. For portraits I have a 50 mm,1,8 . Thank you .
John ­ from ­ PA
Joined May 2003
Mar 27, 2013 06:52 |  #2
On a 60D, taking into account the 1.6 crop factor, I would think the 17-55 f/2.8 would likely be more useful. That would yield an "equivalent" field of view, as would be seen on a full frame body, over 27-88mm.
pman67
Mar 27, 2013 10:23 |  #3
I second what John said. On your camera, the 24-70 would appear to have the view of a 38 mm lens on the wide end. That isn't wide at all for outdoors where you would want a wide angle to take in the views
-Phil
mondmagu
Joined Jul 2011
Mar 27, 2013 13:44 |  #4
I third that,the EF-S 17-55 is the best EF-S lens available and is a perfect match to the 60D,it's the combination I have and 90% of my shots are from this combination.
Des
ceegee
Mar 27, 2013 13:57 |  #5
It depends on whether you tend to shoot wider or longer. I never really liked the 17/18-50/55 range on my camera, and have been much happier with a lens that offers more range. I recently had to make a similar choice to yours. For the last several years I've been using a Tamron 28-75 on my 7D. However, the Tamron's slow focusing was a problem, and based on the recommendations from this forum for the 17-55, I started using my old 18-55 kit lens again, to see if I'd be happy with the focal range. After a trial lasting a couple of weeks, the answer was a resounding "no", and I eventually bought a Canon 24-105L instead of the 17-55. I'm very happy with it; for me, the broader range was more important than the wider end of the lens. In your case, if you're thinking of using the lens in a fishing boat, you might want to decide if 24 mm is wide enough. In my experience, 24 mm or 28 mm is plenty wide enough for landscape shots; it's the close quarters of the fishing boat that might be a factor for you.
There's no perfect solution here. It's a matter of identifying the compromise you can best live with.
Gear: Canon R10, Canon RFS 18-150, Canon RF 100-400
BigLobowski
Gallery: 188 photos
Joined Sep 2012
Mar 27, 2013 14:15 as a reply to  @ ceegee's post |  #6
You might also want to consider the 15-85 for versatility on a crop...again - all depends on what you intend to shoot as there just isn't a perfect "do everything" zoom combination.
- Ken
Gear List | Facebookexternal link | Flickrexternal link | 500pxexternal link | FeedBack |
GreyStoke Photographyexternal link
Jersey ­ devil
Mar 27, 2013 14:20 as a reply to  @ BigLobowski's post |  #7
Ken brings up a good point, you might want to look at the 15-85. Great focal length if you could do without the 2.8
Orenishii
Joined Nov 2012
Mar 27, 2013 14:42 |  #8
I'll 4th the 17-55mm first off I've owned the 24-70mm on my 7D. My thinking was that'll go full frame at some point. Didn't really work out that way. I found that the 24-70 (38-112mm) range just wasn't wide enough as an all round lens but great for portraits. I ended up selling it and bought the 17-55mm(27-88) IS which i total love, also having IS and it weighing less I seem to have more images thats are keepers, yes i think i've got shaky hands in my old age :). I'll most-likely get the 24-70mm when i finally go full frame.
Canon 7D, EF-S: 17-55mm IS/ 10-22mm/ EF: 45mm TSE/ Sigma 70-200mm macro II / Sigma 30mm f1.4
Facebook (external link)
number ­ six
fully entitled to be jealous
Mar 27, 2013 15:02 |  #9
Agreed on the 17-55, but for a different reason.
If 55mm isn't long enough for a shot it's easy to crop a bit in PP to get the equivalent of a 70mm field of view. Your 60D has plenty of pixels to allow cropping without loss of quality.
If 24mm isn't wide enough you've got bit of a struggle to simulate a 17mm fov...
-js
"Be seeing you."
50D - 17-55 f/2.8 IS - 18-55 IS - 28-105 II USM - 60 f/2.8 macro - 70-200 f/4 L - Sigma flash
vali003
Mar 27, 2013 16:28 as a reply to  @ number six's post |  #10
Thank you ,I will go for 17-55 .
maccarlos
Joined Mar 2013
Mar 27, 2013 17:13 as a reply to  @ vali003's post |  #11
I agree with the Canon 17-55mm lens. I have the Canon 60D and it is a great range for me. Sure it would be nicer sometimes to have a little more reach, but with shaky hands, on a moving boat, the image quality is beautiful with the 17-55. Best lens I have ever used.
Canon 5D Mark III, Canon 60D, Canon 24-105 F4 IS, Canon 70-200mm F4 IS Canon 17-55mm, Canon 85 1.8mm, Canon 50 1.4mm
1,535 views & 0 likes for this thread, 10 members have posted to it.
521 guests, 136 members online
