I was planning to turn it ON for my coming milky way photography without a tracking mount.
I was curious how much the 'long exp. noise reduction' reduce noise at very high iso.
I did a simple test and it didn't come out as expected. Why?
Using LR4, I increase exposure by 1.45 to make it more obvious. The test has been repeated with very consistent result.
Turning long exp. noise reduction on, lens cap on and covering the VF, I notice:
-it does reduce big white pixel (that's hot pixels, isn't it?). good.
-but it introduces more 'fine' 'random' noise
-the histogram shifted to the right, it means more noise.
Turned on:
Full size jpeg:
Turned on: http://www.4shared.com …=20130329-172506-af9db705
Turned off: http://www.4shared.com …=20130329-172524-cba1a4de
RAW:
Turned on: https://www.dropbox.com …l2dzblooo9sm/On%20RAW.CR2
Turned off: https://www.dropbox.com …p0u8gsr93yz/Off%20RAW.CR2
Can someone please try on any canon body with this function and tell me what's your result? You can even see the differences on the back of your lcd.
Thank you
