Hullo,
Anyone knows how to get this effect
using curves in PS?
TIA
Mar 31, 2013 10:56 | #1 Permanent banHullo, 'The success of the second-rate is deplorable in itself; but it is more deplorable in that it very often obscures the genuine masterpiece. If the crowd runs after the false, it must neglect the true.' —Arthur Machen
ssim POTN Landscape & Cityscape Photographer 2005 10,884 posts Likes: 6 Joined Apr 2003 Location: southern Alberta, Canada More info | Mar 31, 2013 13:01 | #2 I don't see anything really special about this image other that it appears to be a scan of a print or negative. What is it that you want to apply to one of your images. My life is like one big RAW file....way too much post processing needed.
Lowner "I'm the original idiot" 12,924 posts Likes: 18 Joined Jul 2007 Location: Salisbury, UK. More info | Mar 31, 2013 13:17 | #3 It says its originally a B&W film. If true, its been artificially coloured so the result is entirely down to personal choice. Richard
Mar 31, 2013 15:43 | #4 Permanent banssim wrote in post #15775638 I don't see anything really special about this image other that it appears to be a scan of a print or negative. What is it that you want to apply to one of your images. The toning. I was aiming for someone giving me a hint about which channel to play with. 'The success of the second-rate is deplorable in itself; but it is more deplorable in that it very often obscures the genuine masterpiece. If the crowd runs after the false, it must neglect the true.' —Arthur Machen
Scatterbrained Cream of the Crop 8,511 posts Gallery: 267 photos Best ofs: 12 Likes: 4607 Joined Jan 2010 Location: Yomitan, Okinawa, Japan More info | Mar 31, 2013 16:02 | #5 If you have ACR/Lr you can start by over warming the image and then pulling down the saturation on the yellow channel. Then pull up the bottom of the tone curve just a smidgen and add some clarity. This is one of those things I find quicker in Lr. If you want to do it with curves you'd have to remember that lifting a channel boosts it's color, while pulling down swings to it's opposite. So pulling down on blue will introduce yellow.
The Adobe Photo Shoppe VanillaImaging.com
Mar 31, 2013 16:53 | #6 Permanent banCapital. Thanks, I'll start there. I was thinking of the split toning controls, but your way looks better. 'The success of the second-rate is deplorable in itself; but it is more deplorable in that it very often obscures the genuine masterpiece. If the crowd runs after the false, it must neglect the true.' —Arthur Machen
| Latest registered member is semonsters 1650 guests, 136 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
