While using my Sigma EF-530 DG Super today, I noticed that the zoom was stuck at 17mm. Odd since I never use the wide angle diffuser card, so I don't know how or why it would activate the 17mm zoom. So, losing my zoom function (yes, I tried manual mode, pulling the card in and out, fresh batteries, etc), I decided to open my flash to see if there was anything that I could do (ended up that I could not do anything). I figured might as well make a DIY guide on how to partially take apart a Sigma EF-530.
*Disclaimer: I am not responsible for any injuries to you or others, or damage to your speedlight and/or properties. You assume all responsibilities for following this DIY guide.
1. First thing's first, I suggest wearing safety goggles.
2. Power off your speedlight.
![]() | PHOTOBUCKET EMBEDDING IS DISABLED BY THIS MEMBER. Photobucket sends ads instead of embedding photos from their free galleries. Click the link (if available) below to see the image in a gallery page. http://i208.photobucket.com …_IMG_4538_zpse44b1ffa.jpg ![]() |
3. Open the battery door and remove the batteries.
![]() | PHOTOBUCKET EMBEDDING IS DISABLED BY THIS MEMBER. Photobucket sends ads instead of embedding photos from their free galleries. Click the link (if available) below to see the image in a gallery page. http://i208.photobucket.com …_IMG_4539_zps3f44a8be.jpg ![]() |
4. To be on the safe side, after removing the batteries, I tried to turn on the speedlight (red LED briefly lit, then turned off). I then tried pressing the "light" and "test" buttons, then moved the switch back to the off position.
![]() | PHOTOBUCKET EMBEDDING IS DISABLED BY THIS MEMBER. Photobucket sends ads instead of embedding photos from their free galleries. Click the link (if available) below to see the image in a gallery page. http://i208.photobucket.com …_IMG_4540_zps2e136d6d.jpg ![]() |
5. Turn the flash onto its side, and use a small, thin flat head screw driver to pry the padding on the head. Be careful to not rip the padding or scratch/dent the plastic. Place the padding sticky side up on a clean surface.
![]() | PHOTOBUCKET EMBEDDING IS DISABLED BY THIS MEMBER. Photobucket sends ads instead of embedding photos from their free galleries. Click the link (if available) below to see the image in a gallery page. http://i208.photobucket.com …_IMG_4541_zps18593d01.jpg ![]() |
6. Remove these four small Phillips screws carefully. Place the screws somewhere where they won't disappear. I also grouped the four.
![]() | PHOTOBUCKET EMBEDDING IS DISABLED BY THIS MEMBER. Photobucket sends ads instead of embedding photos from their free galleries. Click the link (if available) below to see the image in a gallery page. http://i208.photobucket.com …_IMG_4542_zps9b86167e.jpg ![]() |
7. Now flip the flash to the other side and carefully pry off the other padding on the head, like in step 5. Place the padding sticky side up on a clean surface.
![]() | PHOTOBUCKET EMBEDDING IS DISABLED BY THIS MEMBER. Photobucket sends ads instead of embedding photos from their free galleries. Click the link (if available) below to see the image in a gallery page. http://i208.photobucket.com …_IMG_4543_zps157a94d5.jpg ![]() |
8. Remove the four Phillips screws like you did in step 6. They're the same screws, but I still like to group these four separately.
![]() | PHOTOBUCKET EMBEDDING IS DISABLED BY THIS MEMBER. Photobucket sends ads instead of embedding photos from their free galleries. Click the link (if available) below to see the image in a gallery page. http://i208.photobucket.com …_IMG_4544_zps5374b153.jpg ![]() |
9. Flip the flash "belly" side up, and carefully remove these two small Phillips screws. They're the same screws as used in the sides, but I still grouped these two separately. Good time to check that you have 10 screws total now.
![]() | PHOTOBUCKET EMBEDDING IS DISABLED BY THIS MEMBER. Photobucket sends ads instead of embedding photos from their free galleries. Click the link (if available) below to see the image in a gallery page. http://i208.photobucket.com …_IMG_4545_zps9b3a36dc.jpg ![]() |
Continue in post #2
