Thread started 03 Apr 2013 (Wednesday) 11:05
CC my first attempt at using the "Brenzier Method"
rivas8409
Joined Mar 2011
Apr 03, 2013 11:05 |  #1
So I did a quick shoot for some friends this past weekend before he left on deployment. I really wanted to give the Brenzier Method a try so I did. A couple lessons learned:
  1. 1) get closer. I was using my 85 1.8 and I stepped back far enough to get them both full body in the frame.
  2. 2) Don't forget to switch the camera to JPEG for these shots. I used 25 shots and was slowed down in PP by having to open them in LR, slight development work (i.e contrast, sharpness, etc), export them as JPEGS, then run them through AUTOSTICH to get the pano, back into LR for crop... Yeah, shoot in JPEG next time for these.
  3. 3) I had my 2 speedlights and stands, why didn't I use one? I think I should have set up at least one speedlight on them since they were in the shade.
Anyway, here's the final result. For my first attempt I don't think it's all that bad and they really liked it. What do you guys think?
I also included a couple others from the shoot.
1. Brenzier Method
2. Natural light. Dappled....yea, but not much full shade at 2:00pm. :-)
3. YN560II with shot thru umbrella camera right
Body: Canon 5DmkII│Canon M50
Glass: Tamron 35mm f/1.4│Canon 85mm f/1.8│Canon 24-105mm f/4L│Canon 135mm f/2L│Canon EF-M 22mm f/2.0
Lights: Flashpoint XPLOR 400PRO│Flashpoint Streaklight 360│Flashpoint Zoom Li-on│AB800
Results: WEBSITE (external link)FACEBOOK (external link)
gibbit1
Apr 04, 2013 06:40 |  #2
I'm going to say right away that I'm just not a big fan of the Brenzier Method. I think you achieved it, but I don't think it really helps here. Getting the proper lighting on your subjects should be your first priority. In the first two, they're the darkest things in the frame. Dark eyes and faces aren't good. In the last, you lit them well enough, but you didn't diffuse the flash or use a fill source, so you have dark shadows around the man's mouth and nose.
My critique would be to concentrate on the basics first, and worry about digital wizardry down the road. All the stitching in the world won't save a poorly-lit shot.
Sorry if this is harsh. I just woke up. :(
"Everything will be alright. I'm from the government and I'm here to help."
Gear: EOS 5DMKII; EOS 400D (infrared converted); Canon 24-105mm f/4 L; Sigma 17-35mm f/2.8-4 EX; Canon 70-200mm f/4 L; Canon 135mm f/2.0 L; Pentax SMC Takumar 50mm f/1.4 with EOS adaptor, Rokinon 14mm f/2.8; only enough knowledge to be a clear and present danger to society.
chauncey
Apr 04, 2013 07:27 as a reply to  @ gibbit1's post |  #3
I really wanted to give the Brenzier Method a try....Don't forget to switch the camera to JPEG for these shots
Why...what were your goals...shooting jpeg when you use LR?
^^^ Agree in total...learn your fundamentals first.
1,004 views & 0 likes for this thread, 3 members have posted to it.
1361 guests, 131 members online
