Thread started 04 Apr 2013 (Thursday) 03:00
Padlock symbol on raw and jpeg files on 5d
jaomul
Joined Apr 2011
Apr 04, 2013 03:00 |  #1
Hi all.
I recently bought a 5d and when I put the files on my computer there is a padlock sign on the files. A google search indicates this is something to do with read/write access. I can access and process the files but the properties do indicate that there is stuff ticked that normally are not ticked on files from my other cameras. I have a few Canon dslrs and none of the others files act like this. Has anyone any idea why the files are different from the 5d? Thanks
Olympus EM5,Nikon d7200,
Olympus 12-50mm, 40-150mm,17mm f2.8,Nikon 50mm F1.8, Tamron 90mm vc, 18-105mmVR, Sigma 18-35 f1.8
tzalman
Fatal attraction.
Apr 04, 2013 04:06 |  #2
A. What operating system?
B. When you view the files where? In what application? Explorer? Finder?
C. Jpg or CR2 or both?
D. "... the properties do indicate that there is stuff ticked that normally are not ticked on files from my other cameras." What "stuff"?
Elie / אלי
Lowner
"I'm the original idiot"
Apr 04, 2013 04:10 |  #3
I would guess its something the previous owner has done but forgotten to remove. I wonder if resetting the camera to its default regime would correct the problem?
Richard
tzalman
Fatal attraction.
Apr 04, 2013 04:41 |  #4
Lowner wrote in post #15789264 (external link)
The camera does have a "Protect Image" function that marks a file as read-only, but I think that has to be applied manually on a per image basis and there is no possibility to set it to be "always on".
Elie / אלי
jaomul
Joined Apr 2011
Apr 04, 2013 05:30 |  #5
Thanks. Tried a reset and its still the same.
Its jpegs and raw. The security settings have an access permission tab. In this section all but the bottom tab "special permission" are ticked in black on the 5d files. Thhese normally are ticked but its a lighter grey tone.
I am using widows 7 64bit and its only if I open a folder in windows to see the file tabs. It probably makes no difference but is different than any other files from other cameras.
The protect for 5d photos is indeed applied individually.
Golden ­ Hunter
Apr 04, 2013 06:32 as a reply to  @ jaomul's post |  #6
This sounds like the general rules and permissions scheme of Windows. Sometimes it can go wonky and apply security settings to an individual folder. I would suggest creating a new folder on your desktop and upload a few files to it from your 5d and see what happens. Also, try moving the "padlocked" files to another folder and see if you get a message stating that you need permission to do this. If you get this message, your problem is with the permissions on that folder.
Brent
5D Mark2 // 16-35 f4L // 70-200 f4L // 17-40 f4L // Sigma 50 f1.4//
580EX2
110yd
Joined Jan 2005
Apr 04, 2013 10:46 |  #7
If you have added any new hardware (HARDDRIVES) and installed an OS or programs recently you may have to tweak the permissions of files that are getting stored on the older drives in your machine. I recently installed a SSD and had a similar issue which was resolved by changing the permissions so that the Programs on the new SSD could access old files stored on a partition.
Hope this helps,
110yd
morph2_7
Joined Sep 2012
Apr 04, 2013 11:21 as a reply to  @ jaomul's post |  #8
Windows 7 files with padlock icon are private files in a non private folder (for example C:\Users\Public\Public Documents). You are the only person who can access (read/write) the file. No other users or groups have permission on the padlocked files. Where do you store the raw/jpg files? I'm guessing you have them in a shared (public) folder.
jaomul
Joined Apr 2011
Apr 05, 2013 13:59 |  #9
110yd wrote in post #15790054 (external link)
Hope this helps,
110yd
Thanks but no new software. it only does this with files from the 5d. The 7d files go the same place and no padlocks
jaomul
Joined Apr 2011
Apr 05, 2013 14:03 |  #10
morph2_7 wrote in post #15790177 (external link)
Its in C:\Users\myname\deskto​p and then the pictures folder in libraries. I might have to give up trying to figure this one out, its just a bit strange. thanks all
3,045 views & 0 likes for this thread, 6 members have posted to it.
911 guests, 118 members online
