Thread started 04 Apr 2013 (Thursday) 13:53
600-ex-rt and st-e3 not working together
jskwarek
Apr 04, 2013 13:53 |  #1
I purchased a new 600-EX-RT and the new ST-E3, right out of the box everything worked perfectly and as expected. Turned both units off from testing and went out to use in real life and they will not link together. If I turn the transmitter on first, then the flash, the flash link light will stay yellow while the transmitter goes green. If I turn on the flash first and then the transmitter then the transmitter will go yellow and the flash will go green. What am I missing? I've done no custom functions, both are set to the same channel and both are set to the same ID.
Any ideas, I'm going bonkers trying to figure it out.
TIA,
Jason
ABOUT ME (external link)
C&C Always Welcome
PacAce
Joined Feb 2003
Apr 04, 2013 14:14 |  #2
Hmmm. The manual says the Link light only lights up as either Green or Red.
Have you checked the channel and the ID set on both units? Try setting them manually.
...Leo
dmward
Gallery: 29 photos
Apr 04, 2013 14:15 |  #3
You have to push the button twice on the flash so that it reads slave.
First push turns it on as master. If there are two masters first one is green second one is yellow.
That permits having two (or more) cameras share the same off camera lights.
gmaize
Joined Jan 2005
Apr 05, 2013 01:49 |  #4
Try turning everything on and pushing the camera shutter once. This should send the setup from the transmitter to the flash units.
--gmaize
kouasupra
Apr 05, 2013 01:56 |  #5
Try a different ID number for both of the unit. Both of the units are using the same ID number right?
jskwarek
Apr 05, 2013 09:37 |  #6
dmward wrote in post #15790749 (external link)
DMWard is the winner and get's a one million internet karma points! I must have stared at the settings for 30 minutes and never noticed they were both set to master. Thank you!
Jason
C&C Always Welcome
dmward
Gallery: 29 photos
Apr 06, 2013 16:11 |  #7
jskwarek wrote in post #15793365 (external link)
Jason
Its easy to do. I speak from experience. :-)
1,469 views & 0 likes for this thread, 5 members have posted to it.
1500 guests, 114 members online
