Thread started 07 Apr 2013 (Sunday) 18:53
Smart Objects
chauncey
Apr 07, 2013 18:53 |  #1
I did this within LR using the adjustment brush...I've never used Smart Objects...could I open this into CS6 as a Smart Object, make an easy selection then redo the adjustment brush activity to a more normal appearance?
IMAGE: http://i329.photobucket.com/albums/l383/chauncey43/goose-selection.jpg
D ­ Thompson
Apr 07, 2013 20:37 |  #2
I don't use LR, but this should work the same as using ACR. Open as a Smart Object. Right click and choose New Smart Object via Copy. Make the copied SO the active layer. Make your selection and add a mask. Double click on the copied SO which should take you back to LR (it goes back to ACR), make your adjustments, and click OK when done. It should show the adjustments on the copied SO.
Dennis
Canon 5D Mk III 5D 20D
I have not yet begun to procrastinate!
BigAl007
Gallery: 556 photos
Apr 08, 2013 02:42 |  #3
Yes if you open it to PS as a Smart Object you could re-edit it, although it would be in ACR not LR. What you have to remember though is that by embeding it as a SO you are effectivly embedding the whole RAW file inside the .PSD/TIFF. This does mean that the original file in LR stays the same.
Alan
453 views & 0 likes for this thread, 3 members have posted to it.
Smart Objects
1718 guests, 103 members online
