Thread started 07 Apr 2013 (Sunday) 19:09
First attempt at Jupiter
Allan.L
Apr 07, 2013 19:09 |  #1
IMAGE: http://farm9.staticflickr.com/8538/8629393798_273759bce7_z.jpg
IMAGE LINK: http://www.flickr.com …/53298814@N07/8​629393798/  (external link)
Jupiter and Moons (external link) by Allan.Leparskas (external link), on Flickr
This was my first attempt at stacking images for astrophotography. I took 17 shots of Jupiter, stacked them in Registax 6, and then blended the stacked image with a single image that was exposed to show the moons. I am still really new to stacking... I barely managed to get these photos to stack! The seeing was pretty poor but I'm happy for my first attempt.
If I remember correctly the exposure was ISO 800 1/80th (forget f-stop) to get jupiter correctly exposed. The telescope is an old 10" refractor that my dad has access too, we t-mounted my 7D directly on it. Focal length is roughly 10-12 feet (somewhere in the 3.x meter range). I use my kenko 1.4x TC for this shot too (just to try it), it seemed to work pretty well.
Would I be better off using video mode like the crop mode on my T2i to stack hundreds/thousands of frames? Or should I just take more full-res images when there is better seeing? I tried to get the Orion nebula too... currently failing at stacking it. It also looks out of focus (bad seeing, same night).
I would love any input for future trips to the telescope.
Allan.L
Apr 07, 2013 21:28 |  #2
Just doing more research, could I buy a 2x 2" barlow lens and attach it in front of my t-mounted camera? Would this be an improvement optically from my 1.4x teleconverter? I know 1.4x isn't 2x, so lets say how would it compare optically to a 2x teleconverter?
Also I found an expensive light pollution filter in the storage room, would this be worth while using? The telescope is in a city of ~400,000 people however it's not like its downtown, but there is definitely a ton of light pollution.
Celestron
Apr 07, 2013 21:29 |  #3
You did very good for first attempt ! Bet the view was even greater ?!
Celestron
Apr 07, 2013 21:35 |  #4
Allan.L wrote in post #15801875 (external link)
A 2x barlow would manify Jupiter to a larger image but if the clarity is not so good you would be defeating your purpose depending the barlow . The Telvue barlows in the Powermate are the best but very expensive ! So depending your budget or if you already have one yes they do help some .
http://www.telescope.c​om …LrqnZOEurYCFQ8G​nQodEzkAfg (external link)
Allan.L
Apr 07, 2013 21:47 |  #5
To be honest I didn't even get any viewing in I was so eager to see what i could get on camera! I'll have to report back next time I go.
Do you mean the quality of the barlow affecting clarity? That and viewing conditions I guess. The scopes optics should be pretty good still even though its several decades old :p Plus its painted orange so doesn't that increase my focal length? :p (i'll put a pic up later). I assume it would degrade IQ like adding a canon 1.4x and 2x TC to a lens, and that you get what you pay for :p Thanks for the link.
Have you ever compared a photography teleconverter to a dedicated astro barlow while t-mounted?
Toxic ­ Coolaid
Apr 07, 2013 22:43 |  #6
he means the clarity and transparency of the atmosphere. If they are bad, your images will be bad too.
Go here and pick a Clear Sky chart near your location. They forecast a day away and are accurate
http://cleardarksky.co​m/csk/ (external link)
here is a map you can choose from
http://cleardarksky.co​m …recs=100&type=t​ext&unit=0 (external link)
Allan.L
Apr 07, 2013 23:05 |  #7
Great links, I had a tough time even getting rough focus the turbulence was pretty crazy. Even after we opened a door and the dome it was pretty bad. There is the odd night were viewing is pretty good though so i'll have to keep my eye out, I really just wanted to get down and try it. I may ask and see if I can borrow a barlow from someone first.
Celestron
Apr 08, 2013 08:09 |  #8
Toxic Coolaid wrote in post #15802107 (external link)
Thanks for clearing that up Toxic . Yes Allen I was meaning atmospheric conditions . If seeing is bad then the more power you add by adding converters or barlows will just make it that much worse . However Barlow qualities theirselfs has a lot to fo with it also . If a barlow is not parfocal with your lens you will have to refocus quite abit between lens and EP changes . Parfocal lens and EPs' keep the focus almost the same as to where very little if any focus is needed .
Viffer
Joined Sep 2011
Apr 08, 2013 09:43 |  #9
Not bad for a first attempt.
Get Backyard EOS software it can shoot video at 30fps and crop your 7d sensor to 5x ( a Barlow or Powermate will be useful too).
Allan.L
Apr 08, 2013 10:03 |  #10
Thanks Ron and Viffer, I plan on trying video next, it seems to be good for planets. I'll check out that software, could I also use my t2i in crop mode? I think there is no compression or anything done to it (from what I read)...
Celestron
Apr 08, 2013 11:15 |  #11
Allan.L wrote in post #15803340 (external link)
If you shoot in RAW which is best you can adjust the WB and for the image size you can usually crop between 50-100% and still have a very nice image depending the out come of images you take . Yes you can use a cam corder or a dedicated CCD camera also for any imaging you choose . Then use Registax to stack the single frames for a final input . Just remember that jupiter has the fastest rotation of all planets so to keep a sharp image keep a set of frames under 2-mins . Video cams can take up to 30+ Frames a second so just a minutes worth of imaging can turn out a couple hundred images and that may take quite a while processing . If you can adjust it which is possible you can take 10-15 per sec which makes the exposure longer and sometimes a better image . Good luck how you do it . if you can you can use a laptop with software to control the cameras and capture the image to your computer so it wont store on your camera .
Allan.L
Apr 08, 2013 15:29 |  #12
Thanks for the info Ron!
Here (external link) is a photo of the orange beast if anyone is interested (not my photo). Looks like it was taken on a public viewing night.
Celestron
Apr 08, 2013 21:43 |  #13
Allan.L wrote in post #15804547 (external link)
Here (external link)is a photo of the orange beast if anyone is interested (not my photo). Looks like it was taken on a public viewing night.
WOW :shock: , that is certainly a beast ! Has the optics been clean ever or do you have that info ? It should bring you some great planet images especially !
Allan.L
Apr 08, 2013 22:23 |  #14
Oh yea, my dad used to use this scope frequently for astro work I think, he said he used to take the elements down to Arizona to get cleaned/coated or what have you. I'm not sure when the last time they were cleaned but it's still used by students/profs. We had another observatory out in the country that had good viewing that he used to use but it got shut down unfortunately.
Come summer time I think i'll have a better chance at planets. I'll keep an eye on the astronomy forecast charts. I'm going to try to get out as much as possible.
Here is a quick shot I snapped. Edit* I should add it was built in 1940 for this observatory, and has obviously been there ever since! Here is some info: http://www.physics.uwo​.ca/outreach/cronyn_hi​story.html (external link)
Untitled (external link) by Allan.Leparskas (external link), on Flickr
Celestron
Apr 09, 2013 08:00 |  #15
Very nice ! Good to know the build yr . Those old scopes were just as good back then as they are now ! I would be very curious how big the images would be for Uranus and Neptune if you ever get a chance to image those two . I have imaged Uranus before and I was excited to get that but it was still small and no detail , just good color tho ! Heres what I got .
4,663 views & 0 likes for this thread, 7 members have posted to it.
1077 guests, 115 members online
