How come cinema cameras use large rectangular lens hoods? Are the equipment requirements in terms of optics for cinematography significantly different from stills photography?
windlight Senior Member 286 posts Likes: 4 Joined Nov 2012 Location: Orlando, FL, USA More info | Apr 07, 2013 23:21 | #1 How come cinema cameras use large rectangular lens hoods? Are the equipment requirements in terms of optics for cinematography significantly different from stills photography? Former Canon fanboy.
Luckless Goldmember 3,064 posts Likes: 189 Joined Mar 2012 Location: PEI, Canada More info | Apr 07, 2013 23:34 | #2 I haven't been around many, but the impression I got was that they were designed to be adjustable so that you set the flaps to the lens and lighting you are using, rather than having a single small hood for each and every lens. Simpler and easier to build as a generic system in that fashion as well. Canon EOS 7D | EF 28 f/1.8 | EF 85 f/1.8 | EF 70-200 f/4L | EF-S 17-55 | Sigma 150-500
iamascientist Senior Member 680 posts Likes: 1 Joined Apr 2010 Location: Mass More info | Apr 07, 2013 23:46 | #3 Your thinking of a matte box. One of the reasons they're so large is because they use square filters (4x4), most cinema lenses also have a very large front diameter.
Apr 07, 2013 23:54 | #4 windlight wrote in post #15802206 How come cinema cameras use large rectangular lens hoods? Are the equipment requirements in terms of optics for cinematography significantly different from stills photography? Terminology note: the devices are correctly called "matte boxes.
windlight THREAD STARTER Senior Member 286 posts Likes: 4 Joined Nov 2012 Location: Orlando, FL, USA More info | Apr 07, 2013 23:59 | #5 DC Fan wrote in post #15802273 Terminology note: the devices are correctly called "matte boxes. Filmmakers often use lights in front of the camera position, so they need larger boxes to prevent flare. Ah ok. Former Canon fanboy.
Apr 08, 2013 05:21 | #6 DC Fan wrote in post #15802273 they need larger boxes to prevent flare. Unless they're called J. J. Abrams Frank Hollis - Retired mass spectroscopist
Kolor-Pikker Goldmember 2,790 posts Likes: 59 Joined Aug 2009 Location: Moscow More info | Apr 08, 2013 06:49 | #7 Unless they're called J. J. Abrams Or Michael Bay... 5DmkII | 24-70 f/2.8L II | Pentax 645Z | 55/2.8 SDM | 120/4 Macro | 150/2.8 IF
| Latest registered member is zachary24 1083 guests, 113 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
