Thread started 07 Apr 2013 (Sunday) 23:41
best/largest storage solution for travelling needs?
the.forumer
Joined Oct 2011
Apr 07, 2013 23:41 |  #1
i'm exploring options other than buying CF cards in bulk and killing my pockets - what alternatives are around?
i see a lot of recommendations for the HyperDrive (http://www.hypershop.c​om …-COLORSPACE-UDMA-s/64.htm (external link)), but i feel it's not worth the price for a dedicated use. hence, i'm thinking of getting the cheapest laptop/netbook/tablet that has 1 full sized USB port that i can plug in my 2.5" external HDD to expand storage.
any recommendations ?
- as light as possible
- 1 USB port that has enough power for ext HDDs
- old models are more than welcome, because i'm intending to buy 2nd hand and save $$$
so far, the best alternative is the Asus EEE Pad Transformer TF101, going for 250 used. let me know if you guys know of better alternatives!
cheers!
gromeo
Apr 08, 2013 22:08 |  #2
I use these to back up all my downloads when shooting on site (500GB Rugged Triple Interface)
http://www.bhphotovide​o.com …&InitialSearch=​yes&sts=ta (external link)
Nikon D4 and 60 2.8D Micro, 24-70 2.8G, 70-200 2.8G VRII, 200-400 VRII, SB800, SB600, Pocket Wizards, 4x WL-1600, Quantum Turbo 2x2, Sekonic 358 meter, TT AS, Takeoff, Belt System
http://rguzmanphoto.ph​otoshelter.com/ (external link)
http://www.romeoguzman​photography.com (external link)
http://www.sportsshoot​er.com/rguzman (external link)
Rashkh
Joined May 2011
Apr 09, 2013 01:10 |  #3
You can buy a similar device for a cheaper price from a different manufacturer. Digital Foci and Wolverine make similar backup options. The downside is spotty reviews and a barebone feature set. They start at about $140.
Alternatively, Sanho makes a Hyperdrive case that requires you to supply your own hdd. That runs $250 so it falls within your budget.
Cheaper cf card backups:
http://www.bhphotovide​o.com …&N=4083163867&s​rtclk=sort (external link)
Sanho Casing:
http://www.bhphotovide​o.com …00_Casing_for_U​DMA_2.html (external link)
samsen
Apr 09, 2013 01:26 |  #4
Laptop's HD is all I need and BTW laptop is a must for me to have PS etc.
External HD would be the next best bet.
Both of above should be taken with attention to your destination's Voltage and electrical connections, in case you need a specific adaptor.
With price of Memory cards dropping so much, that would be the third best option. Unless you must take a large nuber of images in RAW that again this may not be adequate for more that a few days. You don't have to deal with electicity compatibilities (Uncless the charger for camera itself).
Weak retaliates,
Strong Forgives,
Intelligent Ignores!
Samsen
Picture editing OK
the.forumer
Joined Oct 2011
Apr 11, 2013 20:18 |  #5
Rashkh wrote in post #15806570 (external link)
Sanho Casing:
hmm, are there even cheaper ones (i don't even mind chinese copies, as long as they perform the sole function of backup) than the Digital Foci/Wolverine brands? cos i'm thinking if i have to spend 140 on a dedicated backup, i'd rather top up a bit more for a full-fledged device (tablet/netbook)..
Wilt
Apr 13, 2013 15:31 |  #6
IBM T-43 is a solid laptop, and this refurbished one comes with the IBM super high res monitor, for a song at $130 (today!). The only downside is 40GB internal drive, but supplement it with an external USB housing holding an SSD drive (shock proof and faster than conventional HDD) or a large external USB conventional HDD.
http://www.rakuten.com ….html?listingId​=213678329 (external link)
cebuRyda
Apr 13, 2013 20:02 as a reply to  @ Wilt's post |  #7
One thing to consider if you use an older USB hardrive. Some need 2 USB ports for the power requirements. Normally the manufacture will supply a "Y" split cable but you'll still need the available ports. Good luck.
5DMKIII Gripped, 7D Gripped, 50D Gripped, Canon 50 1.4, 35 2.0, 85 1.8, 70-200L 2.8IS, 17-40L, 28-135, 100-300, 580EX, 580EXII & S100
Gallery (external link), My Blog (external link) and Facebook (external link)
2,082 views & 0 likes for this thread, 6 members have posted to it.
1504 guests, 134 members online
