Thread started 08 Apr 2013 (Monday) 03:00
Macro ringflash and slave units
Mystery57
Joined Mar 2013
Apr 08, 2013 03:00 |  #1
Does anyone know if the MR14EX ringflash unit will control a 580EX2 as a slave for macro photography ?
Im a newbie to using flash and unfortunately dont have manuals for either of these units.
If I can use them together could someone give me an idiots guide to setting them up
If not compatible - is there a relatively cheap slave unit I should be looking at buying ?
Many thanks
yipDog ­ Studios
Joined Nov 2012
Apr 08, 2013 03:30 |  #2
Don't know if it will wirelessly (will play and add post with results) but I'm planning on experimenting with my ring flash along side my AB monolights. I will have the ring flash on the camera and use a cable to run from the camera to my Impact radio trigger which will fire the AB. Probably an easier way to get there but i have time on my next shoot to play a bit. Should be interesting!
The Impacts are really cheap and work great.
www.yipdogstudios.com (external link) http://yipdog.smugmug.​com (external link)
1Dx, 5D mk3, 70D, C100, glass for all occasions, and a studio full of support gear!
pturton
Joined May 2002
Apr 08, 2013 12:52 |  #3
http://www.usa.canon.c​om …_14ex#Brochures​AndManuals (external link)
The manual suggests that the MR14-EX is capable of being a master flash to other EX flashes
Mystery57
Joined Mar 2013
Apr 08, 2013 12:56 |  #4
many thanks
butterfly2937
Gallery: 378 photos
Apr 08, 2013 17:41 |  #5
Yes it works great I often use it that way.
GEAR
butterfly2937
Gallery: 378 photos
Apr 08, 2013 17:46 as a reply to  @ butterfly2937's post |  #6
I have not had success putting the ring flash on a radio trigger because the ring flash is actually 2 flashes in one. The built in line of sight triggering works great just make sure the slaves can see the master ring flash. You can use ratios and assign any number of flashes to groups A, B or C.
GEAR
Mystery57
Joined Mar 2013
Apr 09, 2013 01:46 |  #7
thank you one and all for the support I look forward to experimenting further with this now
1,092 views & 0 likes for this thread, 4 members have posted to it.
2374 guests, 102 members online
