Thread started 08 Apr 2013 (Monday) 21:20
Digital Photo Professional SW - Image quality
Mafort@Brazil
Joined Apr 2013
Apr 08, 2013 21:20 |  #1
Hi.
It is my first post. I am phographing with my old 400D Camera (Raw pictures). I processed them using the Digital Photo Professional SW (supplied with the camera). Eventhoug I "save as.." in tiff format and open it with photoshop or any other SW, image quality seems to be different when I compare the visualization in Canon SW and Photoshop. In Canon SW the image seems to be better.
Any idea?
Thanks a lot.
Leimar
René ­ Damkot
Apr 09, 2013 02:02 |  #2
Don't use "Save as", use "File > Convert and save" to export it as a tif or jpg (use "Batch Process" for more then one image).
AdobeCamera Raw cannot read the DPP adjustments (and vice-versa), so you need to render the image for Photoshop (proper) to be able to open the image.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
tzalman
Fatal attraction.
Apr 09, 2013 02:54 |  #3
Are you saying that the DPP preview before you convert and save to tiff looks better than the tiff does when opened in Photoshop? Can you please describe in what ways they are different; in color, tonality (lighter or darker), contrast, sharpness or what?
When comparing any two programs it should always be done with the image at 100% zoom (also called "full sized" or "1:1") because every program has its own way of reducing an image to make it fit the screen and some are better than others.
Elie / אלי
Lowner
"I'm the original idiot"
Apr 09, 2013 03:57 |  #4
I don't recognise the SW the OP has attached to DPP. Can someone explain?
Richard
René ­ Damkot
Apr 09, 2013 04:07 |  #5
SoftWare I presume?
I also see now that the OP mentioned "Save as a tif", so it might be my post is moot ;)
Lowner
Apr 09, 2013 05:13 |  #6
René Damkot wrote in post #15806827 (external link)
SoftWare I presume?
Thanks Rene.
Richard
Mafort@Brazil
Joined Apr 2013
Apr 09, 2013 20:25 as a reply to  @ Lowner's post |  #7
Hi. Thanks for all the replies.
I uploaded one example. The image in photoshop has a smaller contrast an smaller saturation. They are both in 100%. I used the option "Convert and Save".
If we see the image in smaller ZOOM the diference is even more noticible.
Thanks again
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/04/2/LQ_644334.jpg
Image hosted by forum (644334) © Mafort@Brazil [SHARE LINK]
tzalman
Fatal attraction.
Apr 10, 2013 01:32 |  #8
The first thing is to be sure your DPP Preferences/Color Management is set up properly. The working space should be the same as the default working space in PS. The monitor profile should be either 'Use OS default' (Windows only) or set to the monitor profile used by the OS. CMYK simulation must be 'None'.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/04/2/LQ_644374.jpg
Image hosted by forum (644374) © tzalman [SHARE LINK]
Elie / אלי
867 views & 0 likes for this thread, 4 members have posted to it.
1718 guests, 103 members online
