Thread started 09 Apr 2013 (Tuesday) 12:26
Wescott Rapid Box Octa review
aboudd
Gallery: 13 photos
Joined Feb 2013
Apr 09, 2013 12:26 |  #1
I just bought a Wescott Rapid Box Octa for an upcoming assignment where I have to travel by air. This umbrella like softbox is 26", works with your shoe-mount flash and only has a one-stop loss with the diffusion material in place. I did an extensive write-up on it along with some photos for you to view. Go to www.foto-gizmo.blogspot.com (external link)
hawk911
Apr 09, 2013 13:11 |  #2
pricey little sucker, isn't it. Any shots with it?
HAWK Photography Gallery (external link) FB Fan page (external link)|_My gear: 5d3, 70D & 40D (all gripped), 580exII, 550ex, Canon 24-70 L & 85 f1.8, 50mm f1.4; Tamron 70-200 SP Di VC, Canon 18-55, Sigma 1.4xtc; Elinchrom Whore, Skyport triggers, Speedotron BD and Kacey Grid, Vagabond minis
dmward
Gallery: 29 photos
Apr 09, 2013 22:42 |  #3
this; http://www.amazon.com …a+softbox+for+p​hotography (external link)
and this; http://www.lightenupan​dshoot.com …Bracket/flashst​rap2.0.jpg (external link)
Are cheaper, and more compact. They probably provide better light since the source is indirect.
I know I like mine without a diffusion panel.
hawk911
Apr 10, 2013 13:29 |  #4
David... you use that flashstrap much?
bobbyz
Apr 10, 2013 15:33 |  #5
No lip.
I will take my alien Bees with SP Systems 37" octa.
Fuji XT-1, 18-55mm
bhursey
Apr 10, 2013 16:09 |  #6
dmward wrote in post #15810316 (external link)
Problem with that first box wouldn't you have the tilt issues like the wescott Apollo?
Cameras: Canon 60D and 20D
Canon EF lens used : 50mm f1.8, 18-55mm f/3.5-5.5, 75-300mm f/4.5-5, 85mm f/1.8, 28-75mm F/2.8 XR Di LD Aspherical (IF)Strobist: Canon 580EX II , 2X YN-568EX, Nikon SB-24, LP-160, Pixel Mago, 4x Cactus RF60 , Voeloon V760 and 331EX, 4x YN622C and (cactus v4, v5, V6)"
http://flickr.com/phot​os/bhursey (external link) | http://brianhurseyphot​ography.com (external link)
hawk911
Apr 10, 2013 16:36 |  #7
mini boom inside might fix that
bhursey
Apr 10, 2013 16:43 |  #8
hawk911 wrote in post #15813118 (external link)
Or you mean the multiboom :D http://brianhurseyphot​ography.com/blog/?p=32​7 (external link) Well depends on the length.
hawk911
Apr 10, 2013 16:45 |  #9
just anything short enough to allow a new angle for the flash units
dmward
Gallery: 29 photos
Apr 10, 2013 17:24 |  #10
bhursey wrote in post #15813008 (external link)
On my blog I show how I do it with a PCB Mini-boom to get the off-set.
Works like a charm.
HAWK, I've moved to the strap thingy after I had a stand go over with a speedlite attached to a cold shoe mount on an umbrella swivel. The momentum from falling tore the flash hot foot out of the cold shoe. I'm sure that Canon is going to ask for about $100 to fix it.
The tip over was outside with a 9" softbox on the flash which probably helped pull it out of the shoe. :-(
And in addition they keep the flash tube close to the centerline.
Elv's bracket is a two edged sword. Its a great bracket for multiple speedlites in an Apollo type device. Especially those around 90Cm.
For a single light, its a bit heavy and starts to make the modifier etc. top heavy on my Cheetah 8s or Calumet mini stands.
hawk911
Apr 10, 2013 17:52 |  #11
was that a 550ex by chance? the 580ex ii is much more robust. I still have a 550 waiting for the shoe replacement.
dmward
Gallery: 29 photos
Apr 10, 2013 18:13 |  #12
hawk911 wrote in post #15813410 (external link)
It was a 600Ex-RT.
Bent the metal foot, and tore it lose from the pins holding it onto the plastic part of the base. Naturally the flash doesn't work via the shoe but it worked just fine as on the strap mount as a remote. :-)
hawk911
Apr 10, 2013 18:24 |  #13
oh.. then the strap is a great idea :)
dmward
Gallery: 29 photos
Apr 10, 2013 21:56 |  #14
I think so.
I was looking around trying to find the best way to DIY something similar. For the price its not worth finding the parts.
Best of all its small and relies on a standard umbrella adapter.
Speaking of which, Phottix sent one of their umbrella adapters along with Elv's bracket for me to test.
Its the best umbrella bracket I've come across so far, and I think I have at least one from about 4 or 5 different sources. The Calumet (identical to Manfrotto) is great but the big T screw for securing the top spigot is aggravating. Keeps getting in the way. And the Phottix has a serrated joint which I prefer.
agv8or
Gallery: 10 photos
Apr 10, 2013 22:11 |  #15
It looks like an Aurora Firefly but a bit cheaper with an inner diffusion panel.
Rand
Gear
7,579 views & 0 likes for this thread, 6 members have posted to it.
1650 guests, 136 members online
