Thread started 10 Apr 2013 (Wednesday) 10:01
Hard drive and memory
Tareq
"I am very lazy, a normal consumer"
Apr 10, 2013 10:01 |  #1
Hi again,
I want an advise from you all, i bought a new laptop and i want to upgrade its memory from 8GB to 16GB, but i don't know which 16GB[2x 8GB] brand i should get, i found Crucial and on newegg.com i saw G.Skill has more reviews, that G.Skill is a bit cheaper, but i really don't know about that site and this brand, i bought Crucial before for my old laptop [8GB then 16GB] and it is working great, what do you recommend?
I am also looking for a 1-2TB internal hard drive to compliment my SSD to use for storage and scratch, i also not sure which brand to go with, WD, Seagate, ....? I will get 7200rpm one, i was thinking to go with Seagate Momentus XT, but i have only 750GB and not sure if that is enough to use for files storage and scratches and such.
Galleries:
http://hamrani.deviant​art.com/gallery/ (external link)
Facebook (external link)
katodog
Apr 10, 2013 10:21 |  #2
Crucial has a scan tool on their site that tells you what type of memory, and how much, your computer will take. Once you know the details you can shop around for the company you want; Kingston, Crucial, PNY, etc.. Memory these days is memory, you won't see much difference at all between the different companies. The only thing you'll see is whether or not reviews are more favorable for one versus another. But in actual practice most companies make memory that's no better or worse than anybody else.
Western Digital laptop drives (any of their drives that are "green") have a parking feature that parks the drive after 4-8 seconds. It does not make it a good drive to use for storing photos, especially if you access the photos for processing. I had to use HDDScan to disable the "green" features of the drive, otherwise every time I paused for a few seconds it'd take a few seconds for the drive to spin up, which made processing a pain in the neck. If all you're doing is using it for straight storage you'll be fine, but if you plan to process from that drive you're gonna see lag times because the drive needs to spin-up if you pause for a few seconds.
The only stupid question is the one that goes unasked - Photographers shoot to thrill, not to kill
My Gear- Flickr (external link) - Facebook (external link) - Smoke Photography - - Sound-Activated Paint
uOpt
Apr 10, 2013 10:39 |  #3
I avoid WD drives like the plaque, especially laptop drives. They always go overboard with cute features and the next thing you know your drive doesn't do a specific thing well.
Crucial had a couple problems at some point. In the end both Crucial and G.Skill use the same reference PCBs and half-random memory chips (at same product designation), so apart from the SPD values and warranty there isn't a real difference that you can control by buying a specific product.
My imagine composition sucks. I need a heavier lens.
Tareq
Apr 10, 2013 10:42 |  #4
katodog wrote in post #15811622 (external link)
I see, i know which memory i can use, i just asked which brand, i did the scan and also checked the specifications of my laptop and know what type of memory it is compatible with, but i ended up or narrowed with 4 options to choose between, i neglected other more.
I didn't understand your point about the hard drive section, i will read it more and try to understand it.
Thanks!
Galleries:
isoMorphic
Apr 10, 2013 10:43 |  #5
What makes one brand better then the next is customer support and Corsair is top notch.
Tareq
Apr 10, 2013 10:50 |  #6
isoMorphic wrote in post #15811692 (external link)
B&H doesn't sell Corsair memories, and i didn't order from newegg before at all yet and would like to try them.
Galleries:
katodog
Apr 10, 2013 10:51 |  #7
Tareq wrote in post #15811688 (external link)
Thanks!
If you have photos on the drive, and you process those photos, if you pause for a few seconds the "green" feature of the WD drive makes it spin down. Which means when you try to resume processing it lags because the drive has to spin up.
Green drives are green because they spin down to save power. The problem is that it slows access time. With my drive I process the photos that are on that drive, so if I leave the green features enabled processing time lags because of the spin down and spin up issue. I took care of that by running HDDScan for that drive, and created a bat file to run at startup.
If all you do is store photos on the drive and don't access them or don't need to access them for processing, then a WD drive will be perfect.
As for failure, or anything else, I've been using Western Digital drives for around 28 years now, and never once have I had a drive fail or have an issue that made it unusable. Their SecurePark (SmartPark, whatever they call it now) feature is an annoyance only if you want to access the drive continuously, otherwise you wouldn't notice the issue.
Tareq
Apr 10, 2013 10:57 |  #8
katodog wrote in post #15811726 (external link)
What about the Blue and Black models of WD? are they different than the green?
What about Seagate Barracuda? I didn't say i want only WD or Seagate but i know those are the top brands of HDD i use, and i am not sure which model of those 2 to go with.
And yes, i want to store photos and also process them, if i will have problems with the spinning then i will choose few photos and transfer them to my SSD and when i finish i delete the original files on SSD i worked on as i have them on HDD as storage, also i have some external storage devices i can use, so i will not put that internal HDD for photos only.
Galleries:
Tareq
Apr 10, 2013 10:58 |  #9
Here is the comparison i chose of 5 memories i look at, what do you think, one of them or pass to another you recommend?
http://www.newegg.com …5%3A%24%24%24%2​4%24%24%24 (external link)
Galleries:
katodog
Apr 10, 2013 11:35 |  #10
Tareq wrote in post #15811765 (external link)
I don't know about other drives besides the WD drives. This si the first drive where I experienced this issue. This one is a WD Scorpio Blue, so it's definitely not just their "Green" branded drives. If you choose a drive, any drive, that has a parking feature, you can just use HDDScan to create a .bat file to run at startup that will disable that particular feature. So far I haven't had any problems after doing that with my drive.
Memory is memory, I had 8Gb in here and upped it to 16Gb, and just chose what has cheaper. Without opening the laptop and looking at it I'd have to say it's Patriot brand I think, got it at Best Buy and so far it's running great. And, it's 10600, where the stock memory was 12800, and my scrawny human brain doesn't know the difference. The laptop screams no matter what I throw at it, and I haven't even had the hint of any memory issues. If you're getting what's recommended by the Crucial scan, just match specs and get what you want, whether it's the best rated or cheapest price. They all boil down to the same set of binary 1's and 0's, 99% of the time our brains wouldn't know the difference.
katodog
Apr 10, 2013 11:35 |  #11
Out of the batch you chose I'd go with Corsair, never had a single problem with Corsair memory in any of the systems I put it in.
Tareq
Apr 10, 2013 11:41 |  #12
Ok, thank you very much!
Galleries:
Tareq
Apr 10, 2013 11:48 |  #13
Crucial scan told me that i can upgrade up to 16GB, this describe "16GB kit (8GBx2), 204-pin SODIMM, DDR3 PC3-12800 memory module".
I found 3 on B&H:
http://www.bhphotovide​o.com …+4141834260+429​4948696+35 (external link)
newegg has the memories a bit cheaper.
Galleries:
isoMorphic
Apr 10, 2013 18:59 |  #14
Lower CAS is better and you don't want value select scraps for almost the same price as Vengeance.
Get the 10-10-10 G.Skill or the Corsair @ Newegg and while the heat spreader is not needed on this type of ram it wont hurt either.
DagoImaging
Gallery: 20 photos
Joined Nov 2012
Apr 10, 2013 19:15 |  #15
isoMorphic wrote in post #15813619 (external link)
This.
Sony a7R3a/a6300/ 16-70/4 / 70-200/4 G / 12-24/4 G/ 24-105/4 G /Sony HVL-60M
3,396 views & 0 likes for this thread, 7 members have posted to it.
1466 guests, 131 members online
