bhursey wrote in post #15821193
Why worry about all the math. That was fine in film days but is it really needed any more.
If folks understood the Inverse Square law, they would never ask
- "Will my flash reach (this far)?"
- "Will my flash overpower the sun?"
...and combined with the simple understanding that HSS immediately loses you -2EV of flash power when your shutter speed is even 1/3EV faster than X-sync speed, they would also never ask
- "I was thinking of using HSS outside as fill flash (and the subject is 15' away)..."
And they would immediately understand that moving the light from 4' away to 8' away makes that light -2EV as bright at the object being illuminated...because double the distance is 1/4 the light, or -2EV. An even the mathematically inept can remember to use distances as f/stops...f/4 to f/8 is -2EV, the same result and NO computation!!!
That's why!
