Thread started 11 Apr 2013 (Thursday) 18:26
What do recommend for focusing rails?
butterfly2937
Gallery: 378 photos
Apr 11, 2013 18:26 |  #1
I am trying to research focusing rails. I really want a 4 way option. What do you recommend and why? I want a stable reliable system. I will be using the system with a 1D body.
GEAR
afoton
Joined Apr 2012
Apr 12, 2013 01:40 |  #2
For coming low, the rail has to have a low profile. It also have to be sturdy, many cheap rails are not. Those fore-after and left-right rails are not even low profile or sturdy.
butterfly2937
Gallery: 378 photos
Apr 12, 2013 10:05 |  #3
afoton wrote in post #15818626 (external link)
So do you have a specific recommendation?
GEAR
afoton
Joined Apr 2012
Apr 12, 2013 14:41 |  #4
No. My only real experiences with focusing rails in field are with a rail from an old bellows I have. For easy using, I have mount an RRS-plate under and a Kirk clamp on the top.
gmillerf
Joined Jan 2012
Apr 12, 2013 22:15 |  #5
I use one of these with a 5D MKII + MP-e and have no complaints about sturdiness. Mine says "Adorama" on the side, but is otherwise identical to others you'll find.
http://www.adorama.com …Oam3LvVxrYCFeNc​MgodImYAKw (external link)
You can see my results here [Skip past all the landscape stuff]
http://www.flickr.com/​photos/79652823@N00/ (external link)
Greg -- http://www.flickr.com/​photos/79652823@N00/ (external link)
butterfly2937
Gallery: 378 photos
Apr 12, 2013 22:28 |  #6
gmillerf wrote in post #15822203 (external link)
Is it sturdy enough to hold a 1D body?
GEAR
gmillerf
Joined Jan 2012
Apr 13, 2013 10:15 |  #7
Do don't know how much a 1D weighs, but my 5D isn't even close to having problems.
gatorlink
Joined Mar 2011
Apr 15, 2013 21:05 |  #8
I suspect the Hejnar dual-stage 8x8 macro rail would suit your needs. I use a single Hejnar 8-inch rail, and I find it to be quite a nice piece of equipment. I regularly use it to stack up to 100 images in the field.
http://www.hejnarphoto​store.com …humrjmmkougdt6j​ao2865h8n1 (external link)
If you want something cheaper, you could try the Velbon macro rail. I used that for about a year. It's a decent piece of equipment, although it's not nearly as sturdy or precise as the Hejnar.
http://www.bhphotovide​o.com …93311&is=REG&Q=​&A=details (external link)
Ryan
butterfly2937
Gallery: 378 photos
Apr 15, 2013 21:19 |  #9
gatorlink wrote in post #15832184 (external link)
Many people seem to recommend the Hejnar rails. The single rails, are they only for vertical adjustment? Can they be used for horizontal adjustments or does the quick release plate not adjust to that position?
GEAR
gatorlink
Joined Mar 2011
Apr 16, 2013 11:03 |  #10
butterfly2937 wrote in post #15832237 (external link)
The single rail that I use can only move closer or further relative to the subject. However, that double rail on the page to which I linked moves left/right as well as forward/backward. I'm not sure how much stability is lost with a rail that move on multiple axes, but in my opinion (and the opinion of all the focus-stacking experts I know of), you really only need a single rail for almost all circumstances unless you are stitching shots in a panorama and focus stacking at the same time.
Ryan
Houston1852
Joined Apr 2012
Apr 21, 2013 17:59 |  #11
I don't use one, but I do have the adorama budget one in the $50 range. Mine seems to sag more than I'd like. That's with the 5D2 and 100mm macro.
butterfly2937
Gallery: 378 photos
Apr 21, 2013 18:40 as a reply to  @ Houston1852's post |  #12
Thanks for all the feedback. The Hejnar rails look really nice. Sagging or slipping is definitely not something I want to deal with.
GEAR
2,998 views & 0 likes for this thread, 5 members have posted to it.
2727 guests, 155 members online
