Thread started 12 Apr 2013 (Friday) 18:18
Looking for a specific type of camera strap
jjmucker
Apr 12, 2013 18:18 |  #1
Hello all. Has anyone ever came across any camera straps that can detach quickly and easily, yet have very little hanging from the camera end?
Given that I shoot photos and video, having the ability to quickly detach my straps if moving from taking images to quickly moving onto a Glidecam, having little hanging on the body end helps greatly.
Any help would be mucho appreciated.
5D3 x 2,5DII,30D,15,24,50,85​,100,24-70,70-200.
Website :
Glasgow Wedding - Portrait Photographer (external link)
Jon
Joined Jun 2004
Apr 12, 2013 19:00 |  #2
OpTech has a variety of connectors (external link), so you can have as much or as little hanging off your camera as you want.
Jon
Cocker Spaniels
jjmucker
Apr 12, 2013 19:54 |  #3
Thanks Jon. I actually have the adapt-it connections from Optech. They came loose on my bodies though. Had them connected via the optech hook, scared the hell out of me.
Website :
Jon
Joined Jun 2004
Apr 12, 2013 21:21 |  #4
Might need to re=examine which connectors you use, then. I doubt you'll find a generic alternative.
Jon
Cocker Spaniels
Scatterbrained
Gallery: 267 photos
Best ofs: 12
Apr 12, 2013 21:45 |  #5
I use the op-tech utility loop:
http://www.amazon.com …8-1&keywords=op+tech+loo​p (external link)
IMAGE: http://i103.photobucket.com/albums/m140/volvo-1/DSCF2029-2.jpg
IMAGE LINK: http://s103.photobucke​t.com …media/DSCF2029-2.jpg.html  (external link)
500px (external link)
1x (external link)
instagram (external link)
The_Bully
Joined Nov 2010
Apr 12, 2013 22:06 |  #6
I have the peak design leash and cuff (external link). It works well for me. shoulder strap is light and easy to pack into a tight camera bag.
T2i | EF 100-400mm f/4.5-5.6 L IS USM | Canon EF-S 17-55mm f2.8 IS USM | Canon EF-S 10-22mm f/3.5-4.5 USM
jjmucker
Apr 13, 2013 12:27 |  #7
ive ordered up the Uni Loop and the 0.75 inch Wide Webbing Connectors , I already have the padded shoulder part.
I looked at the utility loop Scatterbrained and may yet still purchase it as I also have the hook from Op-Tech.
Website :
barfbaggs
Joined Feb 2013
Apr 13, 2013 12:47 as a reply to  @ jjmucker's post |  #8
Just ordered this myself. Seems like it may be what you are looking for.
http://www.amazon.com …-binoculars/dp/B0043WKR​CW (external link)
jjmucker
Apr 13, 2013 13:21 |  #9
Yes that's pretty much what Ive ordered, only Ive ordered them separately as i already have the shoulder pad
Website :
gakoenig
Apr 13, 2013 13:30 |  #10
Minimizing the amount of dingus left on the camera from any sort of a quick release system is a challenge I am intimately familiar with.
Canon makes it especially difficult due to their obsession with brackets. The only thing a bracket is designed for is the 12mm webbing on the ends of the factory strap. To get a quick release function, we have no option but to add something. OpTech's AdaptIts are promising, but they wear out. We are looking to adapt the same carbon fiber filled material we use to make a stronger implementation with our long filliment carbon.
Nikon's pro cameras are all built around lugs, which is much easier. Simple, very strong, totally reliable split keys are super easy to clip something onto.
http://lu.ma (external link), greg@luma-labs.com (external link)
jjmucker
Apr 13, 2013 13:37 |  #11
Tell me about it. Its a challenge trying to find the correct strap. I do not trust the adapt-its, there's clearly a design flaw with them used in conjunction with their hook/swivel system. My body dropped to the ground twice with them, had to remove them.
Hopefully with what Ive ordered should do the trick. Hopefully uni loops will work ok with the Glidecam, any sort of weight tips the balance off but if i can somehow balance the Glidecam with the uni loops attached it may be alot better than what im using just now
Website :
NU27D
Apr 13, 2013 19:14 |  #12
jjmucker wrote in post #15821750 (external link)
jjmucker, could you elaborate some on the Adapt It's coming loose?
Mine seem bullet proof!
Thanks!
gakoenig
Apr 13, 2013 19:57 |  #13
NU27D wrote in post #15824636 (external link)
Thanks!
Not to answer for him, but the OpTech hook is known to accidentally release due to twist condition. OpTech will admit this if you speak to their support folks, and we've seen it happen in testing.
This is why all non-locking gate hooks are a bad deal for cameras:
http://vimeo.com/55080​797 (external link)
In our testing, AdaptIts are pretty solid. They are tough polyurethane, but we have seen failure on them begin by being rubbed against sharp brackets (older cameras, especially) or on brackets with a sharp nick or gouge in them. Those brackets would also have toasted standard 10mm webbing connectors pretty quick, so not really the AdaptIts' fault.
Heath
Joined Sep 2009
Apr 13, 2013 20:00 |  #14
This is exactly what I do as well.
I will also use a 1" arca clamp with a Black Rapid ring on it to connect to the L-bracket.
I love this system for the versatility.
Heath
"Some photographers push the envelope. Some sit behind a keyboard and criticize their accomplishments." (seen in the comments of a photo article)
Blog (external link)-Twitter (external link)-Zenfolio (external link)-500px (external link)-Pinterest (external link)-Gear List
jjmucker
Apr 14, 2013 05:32 |  #15
Yeah, perhaps it was the hook and not the actual small adapt-it, either way, it came loose twice and I didn't trust it after that. If it worked, it would have been brilliant as it was exactly what I was looking for. Maybe if I could source a better hook to use with the adapt-it....
Website :
8,922 views & 0 likes for this thread, 12 members have posted to it.
1186 guests, 136 members online
