Thread started 13 Apr 2013 (Saturday) 18:08
"Best" SD-card?
JohanBorjesson
Joined Mar 2013
Apr 13, 2013 18:08 |  #1
Looking to upgrade from my Sandisk Secure Digital 8GB Ultra SDHC 30MB/s Class 10 to a 16 or 32GB card. Any suggestions?
500px (external link)
JohanBorjesson
Joined Mar 2013
Apr 13, 2013 18:16 |  #2
I'm also wondering if the write speed does make a difference? I mean I've found cards that are 90MB/s.
samsen
Apr 13, 2013 18:36 |  #3
It all comes down to what are you going to use that card for.
If it is a HD video recording, RAW still shooting at burst mode, then YES.
If a simple old video camera or still camera; No.
Some newer cameras will not record video in full frame rate and frame size if you are not using the very high writing speed card.
Weak retaliates,
Strong Forgives,
Intelligent Ignores!
Samsen
Picture editing OK
JohanBorjesson
Joined Mar 2013
Apr 13, 2013 18:37 |  #4
samsen wrote in post #15824556 (external link)
Only still shooting, RAW+JPEG and I am doing alot of burst as well.
PapaGary
Apr 13, 2013 18:50 |  #5
Sandisk has a Product Compatibility Tool (external link).
Jon
Joined Jun 2004
Apr 13, 2013 19:07 |  #6
Any (reputable brand) Class 10 is fast enough for even HD (1920x1080p) video; faster transfer rated will matter more (if your camera has a high enough bandwidth bus to the card) if you shoot bursts a lot. The limiting factors in burst mode are
  1. The size of the camera's buffer (as long as that's got room, you can keep shooting; fortunately that's a published (and reasonably consistent) number.
  2. The speed of the camera's data bus between buffer and card. That's not really documented anywhere, though, so you're just taking a chance going for high speed cards. There's a point at which card speed won't affect transfer rate.
Note, too, that burst mode doesn't just mean holding down the shutter button to hear that machine-gun rattle. I've filled buffers in single-shot mode but with a lot of action. Takes longer than if you're letting the camera rattle along at max. frame rate, but it can be done. And card speed may be a bigger factor here than in "pure" burst mode, since there's more chance for the camera to write out to the card between frames.
Jon
Cocker Spaniels
samsen
Apr 13, 2013 20:27 |  #7
^ T4i is very selective.
Any card less that 30 mbs writing speed, will record video only for one second before giving error message.
Weak retaliates,
Strong Forgives,
Samsen
Picture editing OK
Jon
Joined Jun 2004
Apr 13, 2013 20:34 |  #8
samsen wrote in post #15824816 (external link)
What brands have you tried?
Jon
Cocker Spaniels
RTPVid
Apr 14, 2013 12:30 |  #9
If I take what you wrote literally, then 30 mbps is not fast enough, since the video bit stream is 5.5 MB/sec (or, 44 Mbps).
However, I suspect you meant 30 MB/sec, in which case that is only about 5 times FASTER than the T4i needs for HD video.
Tom
jbrackjr
Joined Dec 2011
Apr 14, 2013 17:21 |  #10
For the 60D any SDHC or SDXC UHS Class 10 card should work just fine. I have the SD Sandisk Ultra, Extreme and ProExtreme in various sizes. They all work the same. The difference in speed that I see is when uploading files from the card to my computer.
Jim
2,520 views & 0 likes for this thread
"Best" SD-card?
Latest registered member is rup_95
735 guests, 197 members online
