Thread started 13 Apr 2013 (Saturday) 23:17
achromatic macro diopter on tokina 11-16
calypsob
Joined Jan 2012
Apr 13, 2013 23:17 |  #1
Has anyone used an achromatic diopter on the 11-16? Opteka makes a 77mm achromatic diopter that I would like to try on the tokina but I want to see some results first. If you have one please post and share the results. I am trying to see how bad the vignetting will be from the filter and also how soft the corners get. I tried adding extension tubes today and it just flat out wont work on such a wide lens so diopters are my only alternative to getting ultra wide macro shots. Thanks
Wes
Gear: Many gears Yes.
calypsob
Joined Jan 2012
Apr 14, 2013 12:32 |  #2
anyone?
Wes
Copidosoma
Apr 14, 2013 16:20 as a reply to  @ calypsob's post |  #3
personally, I can't see one practical reason why you would combine that lens with a macro adapter.
So, you might find it hard to find opinions as I doubt there are more than three people on the planet who have ever tried it.
Gear: 7DII | 6D | Fuji X100s |Sigma 24A, 50A, 150-600C |24-105L |Samyang 14 2.8|Tamron 90mm f2.8 |and some other stuff
http://www.shutterstoc​k.com/g/copidosoma (external link)
https://500px.com/chri​s_kolaczan (external link)
ZoneV
Apr 14, 2013 16:45 |  #4
For super wide angle macro this combination could be useful. But I do not have this lens - and use other lenses for wide angle macro images (short extension tubes (external link) and relay lenses)
DIY-Homepage (external link) - Image Gallery (external link) - Gear List
calypsob
Joined Jan 2012
Apr 14, 2013 21:44 |  #5
Copidosoma wrote in post #15827362 (external link)
Ok well I'm hoping someone has some 77mm diopters to test out before I make a purchase. In these shots you can see what I'm aiming for. I have been trying to impose near infinite foregrounds, with a diopter I would do a focus stack on a tripod so that I could macro focus the diopter and then remove it to focus the middle of the field. I have not decided if I want the far background in focus yet but I like were it's going, feels cinematic or tilt shifty? not sure but lots of fun. All of these shots are at 11mm I believe.
IMAGE: http://farm9.staticflickr.com/8389/8651038530_6887f9df3e_b.jpg
IMAGE LINK: http://www.flickr.com …/70374000@N08/8​651038530/  (external link)
shot out field (external link) by LMNO Sunset Deluxe (external link), on Flickr
IMAGE: http://farm9.staticflickr.com/8379/8651038868_5a4bac93dc_b.jpg
IMAGE LINK: http://www.flickr.com …/70374000@N08/8​651038868/  (external link)
pink (external link) by LMNO Sunset Deluxe (external link), on Flickr
IMAGE: http://farm9.staticflickr.com/8406/8649939643_a25699d25f_b.jpg
IMAGE LINK: http://www.flickr.com …/70374000@N08/8​649939643/  (external link)
fake rosemary (external link) by LMNO Sunset Deluxe (external link), on Flickr
IMAGE: http://farm9.staticflickr.com/8520/8649939879_b5c52020c7_b.jpg
IMAGE LINK: http://www.flickr.com …/70374000@N08/8​649939879/  (external link)
cloverfield (external link) by LMNO Sunset Deluxe (external link), on Flickr
IMAGE: http://farm9.staticflickr.com/8261/8649940087_6fe7009ce1_b.jpg
IMAGE LINK: http://www.flickr.com …/70374000@N08/8​649940087/  (external link)
cinemaesque (external link) by LMNO Sunset Deluxe (external link), on Flickr
In each picture I focused either the foreground, which does not work closer than a foot, or on the middle of the field. Was not sure if I would want the foreground out of focus but now I certainly want it in focus so I would really need a diopter to make the concept work.
Wes
ph2003
Apr 14, 2013 23:46 |  #6
How about addibg a macro extension tube?
ZoneV
Apr 15, 2013 03:00 |  #7
I wonder wheter combining images made with and without diopter could be stacked.
Focal lenght is changed, and probably even perspective point.
ph2003 wrote in post #15828716 (external link)
Normal shortest extension tube is 12mm long.
With a 11mm focal lenght this results near 1:1 magnification ratio. And object plane is probably very near or inside the front lens.
This is a reason why I DIY mad a 8mm extension tube (external link) and6mm short macro EF extension tube (external link).
With the 6mm tube I can use the Zenitar 16mm Fisheye lens, and Samyang 14mm/2.8 for macro wide angle images - and all longer focal lenghts too.
calypsob
Joined Jan 2012
Apr 15, 2013 03:43 |  #8
ZoneV wrote in post #15828959 (external link)
Yea I didn't think about the focal point changing, I have never used a diopter before and I may just have to bite the bullet and buy one, not to expensive but if it does not work I have no other 77mm threaded lenses. Interesting that you bring up the extension tubes idea, mine obviously did not work but it seems that your machine work led to success, congratulations with that. I bet you could do pretty well marketing wide angle extension rings.... Is 16mm the limit or do you think you could get down to 13mm with a 3mm ring?
Wes
ZoneV
Apr 15, 2013 04:48 |  #9
Thank you!
For Canon EF 6mm thickness is more or less the limit - with my current machining and planning setup.
Shorter Canon EF extension tubes are probably (not for sure) possible as a skeletonized version - but I did not spend time for thinking about a shorter one. Probably such extra short will require a different way of lens mounting or such.
For the 16mm lens the 6mm extension tube is not ideal: For me ideal extension tubes result in a more or less contious magnification range. This results in extension tube thickness as thick as lens helicoid focus range (for lenses with helicoids). These super widenagle lenses ar a kind of problem for this wish.
hollis_f
Apr 15, 2013 05:39 |  #10
calypsob wrote in post #15828391 (external link)
You could try the 10-22. MFD is 9.5" which is quite a lot closer than the 11-16's 12" - LINK (external link)
Frank Hollis - Retired mass spectroscopist
Give a man a fish and he'll eat for a day. Teach a man to fish and he'll complain about the withdrawal of his free fish entitlement.
Gear Website (external link)
SteveInNZ
Apr 18, 2013 19:24 |  #11
Hehe. Don't you love it when people make sweeping statements like that. :)
It's a very popular combination in underwater photography, due to the optical properties of a dome port where infinity is a lot closer.
Google it if you're interested.
Anyhow, since I have that lens on the camera and a Canon 500D achromatic diopter handy, I just did a quick test. Putting the diopter on brought the minimum focus about 60mm closer at 11mm, wide open.
A cheaper option than buying another lens or even the diopter, is to stop it down. At f/22 it is focused right up to the filter.
Steve.
"Treat every photon with respect" - David Malin.
calypsob
Joined Jan 2012
Apr 22, 2013 03:29 |  #12
SteveInNZ wrote in post #15843226 (external link)
Steve.
Perfect, Thanks steve!
Wes
2,528 views & 0 likes for this thread, 6 members have posted to it.
1609 guests, 140 members online
