Thank you for turning editing on. It would have been too cumbersome to try to explain the changes I would have made if it were mine. First, I would have increased the saturation. My method of choice is duplicate the layer and set the blend mode to Soft Light.
Second, I would have wanted to get rid of the distracting horizontal line on the left that is created where the branches suddenly become full (440 pixels down from the top if you are counting). So I cropped the left edge.
Third, I took a look to see what did not add to the shot: a lot of foliage. Yes, the shot is in the woods, I get that, I don't need all of the vegetation there to know that. Once the environment is made, too much context can take away from the subject. So I cropped the right edge.
Fourth, I noticed, as others did, that the pool cuts the shot in half. I (more or less arbitrarily) chose to keep the fall and not the stream as the subject. So I cropped the inferior edge.
All that being done, I do wish there was just a smidgen more room above the top of the falls. Oh well, if wishes were horses...
Below is what I ended up with, which, to me, look cleaner and more to the point.
I would like to address something that colliewalker1 said.
colliewalker1 wrote:
I totally agree : photographing waterfalls using a slow shutter speed seems to be 'compulsory' these days ...
I agree, but I ask, why not?
When I was a pup, I worked in an Ice Rink for about 4 years. I got to know a lot of the skaters, including some that went to the '80 Olympics. Back then they were graded on "compulsories" as part of their ranking. Specific moves, done in specific ways. What they learned what technical proficiency. It built foundational skills that later carried over to the creative part of their skating.
This type of "waterfalls using a slow shutter speed seems" is a quick and easy way for a novice or journeyman photographer to learn long exposure technique, and create a pretty passable shot first time out. I was, and still am, proud of my first "slow waterfall" shot. It was one of the first shots I did that rose above the rank of snapshot to something that required forethought, equipment, planning, and an amount of craft.
I say that if they are not, in fact, compulsory, they should be. They are often the first step into a world of creative photography and should not be dismissed lightly.
Rad
