Thread started 15 Jan 2006 (Sunday) 21:35
Need help please. CS newbie question.
retro
Joined Jun 2004
Jan 15, 2006 21:35 |  #1
I am working through the "workflow" section of a Kevin Ames book. It asks me to export cache in photoshop so I clicked the necessary buttons, but I do not understand what exporting cache means and where does it go? On top of it all....how do I burn these "exported" files to cd? Is there a shortcut? I am so lost!
Rob
Canon 5D, 20D,50mm1.4, Canon 24-70 2.8L, Canon 15mm fisheye, Canon 16-35 2.8L
Canon 70-200mm 2.8is
550ex x 2
www.robertkruegerfoto.​com (external link)
tim
Light Bringer
Jan 16, 2006 17:17 |  #2
I see no reason to export a cache, since it can be rebuilt easily. Exporting your image settings (exposure, brightness, etc) makes more sense if you usually use a centralised cache to store those settings - I set it to put the settings in xmp files in the same directory as the image.
Edit - if you don't know why you're exporting the cache why are you bothering to try?
retro
Joined Jun 2004
Jan 16, 2006 22:35 as a reply to  @ tim's post |  #3
I know what you are saying. I am doing it because I want to follow the "lesson plan" perfectly to see if his workflow will work for me. It currently is leaving me stuck, but i don't want to dismiss his ideas because I cant catch on to them as quickly as I would like.
550ex x 2
kram
obvious its pointless
Jan 16, 2006 23:06 |  #4
Rob,
scott Kelby explains the use of the cache and why you need it - its useful only when you want to keep your pics in a backup storage - like a CD.
It doesnt have to part of a regular workflow - just when you are done with a set of pics and want to move it to backup.
Canon 7D , Canon 6D, 100-400 L, 24-105 F4 L, 50 F1.4, Tokina 12-24 F4, Kenko Teleplus Pro DG 1.4X Extender
My Gallery (external link)
FlyACL
Jan 16, 2006 23:25 |  #5
Well let’s start with the information you didn't include in your post. I can only assume you are talking about CS2 (not just "photoshop") and you are actually working in Bridge. It's pays to be specific if you really want good info. Given that ~
In CS2 or really Bridge, The cache stores thumbnail, metadata, and file information to shorten loading times when you return to a previously viewed folder. You can see this happening when you load a new batch of photos into Bridge. Slowly the files go from small previews to the larger previews and looking the "clock" running in the lower right hand corner.
Again it's only use is to speed up the process of viewing thumbnails and EXIF data or file info. It DOES NOT have anything to do with settings or changes you make to your raw files. These changes are saved in one of two ways, XMP sidecar files or a central Camera Raw database (not to be confused with a centralized cache). This choice can be made form the Edit->Camera Raw Preferences option in Bridge. If you haven't got that far in your book yet, keep reading. But really the difference between them is another topic all together.
Back the cache. You have a choice here as well. You can use a centralized cache or a distributed cache. You can make this choice form the Edit->Preferences->Advanced option in Bridge. The difference here is either this thumbnail/file info is stored in one central location, or is stored within each folder with it's respective images. Each has it's good and bad, but generally a centralized cache is easier to work with. One reason being that every once and a while it can be helpful to purge the cache if it becomes corrupted.
Like I said before, If you use a distributed cache the files are stored in the folder with the images. But, they are HIDDEN FILES. If you want to see them you have to use the View->Show hidden files option in Bridge. Regardless if you show them or not, they will be transferred to a CD if you move and burn the entire folder.
If you use a centralized cache, the option to Export Cache will then be available to you form the Tools->Cache menu. This is of course because the files are not stored in the folders with the images, but instead in a central location you set from the Edit->Camera Raw Preferences menu.
When you choose Export Cache you will get two files (there are always 2 cache files) one ending in .BC and one ending in .BCT. They will be exported to the folder you are viewing when you choose the Export Cache option. If you don't see them in the folder while using Bridge it is again, because they are considered hidden files and you have to select View->Hidden Files. If you navigate to the folder outside of Bridge, you should see them just fine.
Now you have your cache and can burn it to a CD or what ever you want to do with it. Funny thing is all of this is a lot of junk do go through just to avoid having CS2/Bridge rebuild the cache when you import the files from the CD. If you don't do any of the cache business, CS2/Bridge will rebuild the cache just as it did when you first loaded the files in from your camera. So really you are just saving yourself a small bit of time. Is it worth it? Maybe... Maybe not... It's up to you to decide.
Take care~
SWPhotoImaging
Joined Nov 2003
Jan 18, 2006 09:22 |  #6
FlyACL, that was an Excellent explanation of the function of cache in CS2(Bridge), and a better translation than I have seen in most books on the topic.
Well done.
SWPhoto-Imaging
980 views & 0 likes for this thread, 5 members have posted to it.
2148 guests, 126 members online
