So hopefully this is a simple answer. So I have a Pocket wizard Plus II. Can it be used with a plus III or should I sell and make the upgrade?
tennfan1125 Member 161 posts Likes: 4 Joined May 2007 Location: lexington,ky More info | Apr 16, 2013 10:49 | #1 So hopefully this is a simple answer. So I have a Pocket wizard Plus II. Can it be used with a plus III or should I sell and make the upgrade? canon 30d, canon 1d mkIII, 50mm 1.8, 18-55mm, canon 1.4 extender, canon 400mm f2.8 IS, canon 70-200 f2.8 IS II, Canon 16-35mm f2.8,Pocket Wizards,430 ex II, 580 ex II, Canon 430 EX, sigma SA-9, 70-300 5.6, 28-80mm(which I NEVER use)
TheLoftStudios Goldmember 1,072 posts Likes: 9 Joined Oct 2009 Location: Houston, Texas More info | Apr 16, 2013 10:52 | #2 Yes, it can..... MARK
PacAce Cream of the Crop 26,900 posts Likes: 40 Joined Feb 2003 Location: Keystone State, USA More info | Apr 16, 2013 10:56 | #3 tennfan1125 wrote in post #15833869 So hopefully this is a simple answer. So I have a Pocket wizard Plus II. Can it be used with a plus III or should I sell and make the upgrade? Yes, you can use the Plus II with the Plus III. However, you will not be able to use all the features of the Plus III, like quad triggering, with the Plus II. ...Leo
xcel730 Senior Member 603 posts Joined Dec 2009 Location: New York More info | Apr 16, 2013 15:49 | #4 To add ... all pocketwizards are backward compatible for the same channels. In other words, PWIII's channel 1 is going to be compatible with channel I from PWII and PWI. ________
| Latest registered member is semonsters 1699 guests, 140 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
